NJ John Samba Member
Joined: September 21, 2007 Posts: 2227 Location: HdG, MD & NJ
Posted: Sat Feb 24, 2024 2:43 pm Post subject: Converting to wide five |
On a 1970 bug, what are factory rear drum options? I was reading that the Thing drum works, but widens the rear track. Does it use the same shoes? I also thought that you could use a 67 drum with a spacer?
Are there any wide five rear disc conversions that don’t widen the track? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
slalombuggy Samba Member
Posted: Sat Feb 24, 2024 7:19 pm Post subject: Re: Converting to wide five |
I used 66-67 bug drums on my irs suspension in the back of my buggy.
CB might offer rear disks with zero offset, I know they do for the front |
Posted: Sun Feb 25, 2024 8:22 am Post subject: Re: Converting to wide five |
Thanks _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Mon Feb 26, 2024 12:17 pm Post subject: Re: Converting to wide five |
The conversion drums that Cip1 sells, look to be bus drums with the snout machined down? Is that possible?
https://www2.cip1.com/c31-501-615-211ag/ _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Mon Feb 26, 2024 4:55 pm Post subject: Re: Converting to wide five |
NJ John wrote: |
Are there any wide five rear disc conversions that don’t widen the track? |
I was under the impression that rear Thing drums were the same as rear Type 3 (which use wider/bigger diameter shoes and backing plates); someone please correct me if I'm wrong (and I'll learn something today as well). _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Mon Feb 26, 2024 5:31 pm Post subject: Re: Converting to wide five |
slalombuggy wrote: |
This is what I have seen done. _________________ modok wrote:
EVfun Samba Member
Posted: Wed Feb 28, 2024 9:35 am Post subject: Re: Converting to wide five |
ALB wrote: |
I was under the impression that rear Thing drums were the same as rear Type 3 (which use wider/bigger diameter shoes and backing plates); someone please correct me if I'm wrong (and I'll learn something today as well). |
The Thing uses Bug brakes parts with wide 5 drums. The rear drums are unique to the Thing, wider than any other Type 1 brake drum but brake internals are the same as the '68 up Bug.
Up front later Bugs can be converted to the wide 5 pattern using '66-'67 Bug front drums. _________________
Wildthings wrote: |
Posted: Thu Feb 29, 2024 12:29 pm Post subject: Re: Converting to wide five |
The Thing drums push the wheel out a bunch. Weird, I guess the drums are just thicker, yet still use the standard late beetle shoes.
I’ll probably go the 67 beetle drum route for the rear and disc conversion for the front. Thanks _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
EVfun Samba Member
Posted: Thu Feb 29, 2024 1:27 pm Post subject: Re: Converting to wide five |
It's a fit, but it's a close fit. This was discussed over in the buggy forum at one point and I included some pictures and my own measurements.
The other thing to consider (no pun intended) is that the all the wide 5 rear drums, except the Thing or aftermarket conversion drums, will have short splines. _________________
Wildthings wrote: |
