ThatKid007 Samba Member
Posted: Fri Mar 01, 2024 6:37 pm Post subject: Thicker wheels / aftermarket wheels |
Got myself a 1976 beetle i want to do my own thing to it
I believe stock height
Pros and cons to thicker tires and rims ??? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76969 Location: Sneaking up behind you
Posted: Fri Mar 01, 2024 6:41 pm Post subject: Re: Thicker wheels / aftermarket wheels |
What do you mean my "thicker"?
Wide, taller or both? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Mar 01, 2024 6:46 pm Post subject: Re: Thicker wheels / aftermarket wheels |
Glenn wrote: |
Wide, taller or both? |
I meant both |
Glenn Mr. 010
Posted: Fri Mar 01, 2024 6:49 pm Post subject: Re: Thicker wheels / aftermarket wheels |
I have 205/60-15 in the rear. You can fit a 215/65-15. Both need 5.5 wide rims, the stock are 4.5.
The front is a bit smaller, you can put 195/65-15 on 5.5 wheels
Member #1009
#BlueSquare |
Posted: Fri Mar 01, 2024 6:51 pm Post subject: Re: Thicker wheels / aftermarket wheels |
Glenn wrote: |
I have 205/60-15 in the rear. You can fit a 215/60-15. Both need 5.5 wide rims, the stock are 4.5.
The front is a bit smaller, you can put 195/60-15 on 5.5 wheels |
Cons for 18” with wider fenders ? |
Glenn Mr. 010
Posted: Fri Mar 01, 2024 6:55 pm Post subject: Re: Thicker wheels / aftermarket wheels |
Bumpy ride, thin sidewall, you'll need custom drums or adapters.
Will look like a VW Donk.
Member #1009
#BlueSquare |
Posted: Fri Mar 01, 2024 7:00 pm Post subject: Re: Thicker wheels / aftermarket wheels |
[quote="Glenn"]Bumpy ride, thin sidewall, you'll need custom drums or adapters.
Thinking something like this |
Glenn Mr. 010
Posted: Fri Mar 01, 2024 7:10 pm Post subject: Re: Thicker wheels / aftermarket wheels |
That's kinda German Look.
That car does not have a stock suspension
Member #1009
#BlueSquare |
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Wed Mar 06, 2024 5:31 pm Post subject: Re: Thicker wheels / aftermarket wheels |
74 Thing Samba Member
Posted: Wed Mar 06, 2024 5:44 pm Post subject: Re: Thicker wheels / aftermarket wheels |
ThatKid007 wrote: |
Glenn wrote: |
Unsprung weight!!!!! |
