Vndlfsn Samba Member
Posted: Sun Mar 10, 2024 7:50 am Post subject: Any road grade too steep for a healthy EVC in 3rd Gear? |
Hello,
My wife and I are planning a trip out west and would love to take our 1997 EVC through the Tetons.
The drivetrain is very healthy, the camper has about 138,000 miles on it and I’ve had everything checked over by our mechanic. I also have a scan gauge to monitor transmission fluid temperature.
I also understand that on steep grades my best practice is to use third gear to lock out fourth.
Question is, are there any fellow for users out there who have experience in navigating steep grades? Are there any recommendations as far as avoiding certain grades or can a healthy camper do just about anything as long as you’re monitoring Engine load and transmission fluid temperature? |
Zeitgeist 13 Samba Member
Posted: Sun Mar 10, 2024 2:06 pm Post subject: Re: Any road grade too steep for a healthy EVC in 3rd Gear? |
'97 is a VR6, right? If so, then you'll be fine with just about anything we have out here in the West. We have a guy in our local camp group with an '00 EVC and he keeps up with me, even though I've got something like 60hp moh powah.
Just keep in mind that for every 1000ft of elevation gain your engine will lose 3% of power, so at 10k ft your 140hp engine will only be producing 98hp. At the same elevation my engine will be producing what your stock engine puts out at sea level. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Mar 11, 2024 5:26 am Post subject: Re: Any road grade too steep for a healthy EVC in 3rd Gear? |
Perfect! I figured as much but thought I would check with some more experienced folks.
We are super excited for our first major trip, the van is running really well if only I could get the cruise control working ha ha. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2798 Location: North Carolina
Posted: Mon Mar 11, 2024 5:39 am Post subject: Re: Any road grade too steep for a healthy EVC in 3rd Gear? |
yeah you should be great. I can get up the steepest highway grades in the Southern Appalachians at 55mph or so, no problem, with the 5-cylinder- in 3rd, that's right at 4-4100k rpm, which I am 100% comfortable running at. So, the 12valve VR-6 should roll up those grades no problem! _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
HeyCrutch Samba Member
Joined: August 12, 2022 Posts: 128 Location: Asheville, North Carolina
Posted: Sat Mar 16, 2024 4:25 am Post subject: Re: Any road grade too steep for a healthy EVC in 3rd Gear? |
I took my 1997 EVC through a ton of mountain passes last fall - Colorado, Utah, Nevada, and NorCal. The thoughest was the climb up a literal wall deep, deep in Capitol Reef NP (hey, the map said "2WD high clearance," haha).
Watch your Trans temps on the climbs. Use a scan gauge II if you don't already have one to see those. The day I climbed that wall in Cap Reef, the trans got way higher than I was comfortable with, but I was 20 miles and 2 hours into the journey and the wall was the only way out. the portion of Escalante that followed did not disappoint.
Don't be afraid to use 1s and 2nd gear locks as well - I used them a lot last fall just to prevent the trans from going back and forth between gears on some of those steeper climbs (rarely 1st, but def used 2nd lock a good bit, below 30 MPH). |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2543 Location: Ocean Beach in Beautiful BLUE California
Posted: Sat Mar 16, 2024 7:38 pm Post subject: Re: Any road grade too steep for a healthy EVC in 3rd Gear? |
Do you have an external transmission cooler? If not, I'd get one...... _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
