Distributor for 1.9
ClareSutton
ClareSutton is offline
PostPosted: Tue Mar 19, 2024 11:55 am    Post subject: Distributor for 1.9 Reply with quote
I have been searching for a new distributor for my 1984 Westy. I know that distributors are available for the 2.1 engine but not for the 1.9. About a year ago Cip advertised a distributor that would fit the 1.9. I bought one and when I received it I noticed that there was only one vacuum pot at the front. I contacted cip and they told me to connect the pot to the line that goes to the throttle body and plug off the other line. I also noticed that the electrical plug on my van was different than the one on the new distributor but cip told me to just make sure the three wires were connected the right way and not to worry about the actual plug. Anyway, I haven't done anything yet and I am wondering if anyone else had bought one of these distributors and if they were successful at making it work. The new distributor cip number is VWC-025-905-205-AD.
COM/DISTRIBUTOR T25-1.9 DF. If anyone knows anything about this distributor I would really appreciate hearing from you.
Xevin Premium Member
Xevin is offline
PostPosted: Tue Mar 19, 2024 12:02 pm    Post subject: Re: Distributor for 1.9 Reply with quote
Email Bill
https://www.sparxwerks.com/
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
SGKent wrote:
fotoroadie
fotoroadie is offline
PostPosted: Wed Aug 14, 2024 2:28 pm    Post subject: Re: Distributor for 1.9 Reply with quote
Can someone help guide me on which wire goes to which terminal spade on this cip1 distributor
3171745 VWC 025 905 205 AD
jlrftype7
jlrftype7 is offline
PostPosted: Thu Aug 15, 2024 10:22 am    Post subject: Re: Distributor for 1.9 Reply with quote
PM DanHoug- he was making adapter test connectors for our Distributors- he probably has the correct wiring for your pin locations. https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=424805
‘84 Tin Top - Hilga....Auto
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Aug 16, 2024 12:28 am    Post subject: Re: Distributor for 1.9 Reply with quote
There you go.
I rebuild these for customers, crimp new spades and connector:
jlrftype7
PostPosted: Fri Aug 16, 2024 5:41 am    Post subject: Re: Distributor for 1.9 Reply with quote
ALIKA T3 wrote:
There you go.
Thanks ALIKA T3- are you able to get the 1.9 connectors as new- or are working off a stash of connectors. I thought, wrongly perhaps, that the 2.1 distributor connector was different from the 1.9 version, and it was very hard to find a new 1.9 style connector.
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Fri Aug 16, 2024 7:40 am    Post subject: Re: Distributor for 1.9 Reply with quote
The 1.9L and distributors are stock with oval connectors. The 2.1 connector is square.
jlrftype7
PostPosted: Fri Aug 16, 2024 8:11 am    Post subject: Re: Distributor for 1.9 Reply with quote
So, from the pictures, people are getting the later 2.1 distributors that are available, and installing them in an older 1.9. Then you need to swap the Oval 1.9 connector for the later 2.1 square version?
Did I get that right? Think
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Aug 16, 2024 8:26 am    Post subject: Re: Distributor for 1.9 Reply with quote
It isn't that simple in USA/CA models.
The 2.1 distributor is a static advance type so all of the advance is done electronically by the Digifant 2.1 ECU.
The 1.9 ECU does nothing for advance, it is all done in the 1.9 distributor.
The 1.9 distributor uses vacuum for part of the advance and rpm for part of the advance.
The 2.1 distributor does neither since the 2.1 ECU takes care of the advance.
Mark
VWNOS.com
heimlich is offline
PostPosted: Fri Aug 16, 2024 8:28 am    Post subject: Re: Distributor for 1.9 Reply with quote
The 2.1 distributor just spins. You can't use it in the older vehicle. There is no advance mechanism in it. They are taking the connector from these types of distributors and using them.
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Aug 16, 2024 10:59 am    Post subject: Re: Distributor for 1.9 Reply with quote
Yes the 1.9L connectors can be bought 3D printed in Germany, Vanagain carries them.
The distributor I rebuilt, pictured is a 1.9L (see the diameter of the shaft and the felt in the center).
It has a new Hall Sender assembly from an Audi with the 2.1L style connector, but to fit, the body notch needs enlarging with a Dremel and I also replace the harness side connector with new pins since I have the crimper, much cheaper than the ugly rip off pig tail from GoWesty.
Vanagain sells such Hall Sender too.
VWNOS.com
heimlich is offline
PostPosted: Fri Aug 16, 2024 1:59 pm    Post subject: Re: Distributor for 1.9 Reply with quote
Do the connectors fit correctly? The ones I have seen which are blue in color fit too tightly. You can press it in but you can't unplug it easily. I think they were chinese and didn't look 3d printed.
I can rebuild your hall sensor with Bosch electronics (not Chinese) for $150.
For $200, I have the tops of Bosch units. Just take your existing one apart and attach it.
https://www.thesamba.com/vw/classifieds/detail.php?id=2660211
jlrftype7
PostPosted: Fri Aug 16, 2024 2:59 pm    Post subject: Re: Distributor for 1.9 Reply with quote
Mark
Right, I had forgotten the ECU control of the Digifant system since I don't live with it day to day...
jlrftype7
PostPosted: Fri Aug 16, 2024 3:01 pm    Post subject: Re: Distributor for 1.9 Reply with quote
Yeah, I bought the Vanagain Hall Sender unit for one of my spare 1.9 distributors. I did have to dress the body of it to fit the OG distributor. I let Ken know that might throw a few people a curve who don't own a Dremel like I do. Razz
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Aug 17, 2024 12:18 am    Post subject: Re: Distributor for 1.9 Reply with quote
I honestly haven't tried the 3D connectors or receptacles myself, I just go ahead and replace the whole Hall sender with a new chinese part, chinese connector. Never had a problem so far.
Been using them too for the 2.1, the model with no wire BS, just need to tap a hole at M4 like the late model distributors, but they're all cast and drilled already for it, so it's easy: run the tap, add a screw, done.
VWNOS.com
heimlich is offline
PostPosted: Sat Aug 17, 2024 6:54 am    Post subject: Re: Distributor for 1.9 Reply with quote
The square connectors are definitely more common. There's even more OEM Bosch parts out there for those.
I try to help keep everything as original as possible for as long as possible.
You have to be careful of some of the connectors like with everything else aftermarket I guess. The connector I plugged into it was so tight I thought I would never get the plug out.
Oval connectors are easy for me to find. You just have to be careful with them. Hold the connector to the side of the distributor while you are unplugging it. That keeps it from moving up and down and breaking so easily.
