90 mm Typ1 Cv Joint allowing more angle ?
raphael BE
raphael BE is offline
PostPosted: Thu Mar 21, 2024 4:50 am    Post subject: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
Hi
Back again with question on putting the split bus in a "light" offroad configuration.
I found that if you want to put more angle on the cv joint the best way to go is the 100 mm 181.
BUT of course this is some extra €€€$$$ while I have and drive with a typ1 IRS conversion kit - being 90 mm Cv joint.
I've been looking the net but couldn't found anything
IS THERE ANY SPECIAL 90 MM CV JOINT ALLOWING MORE ANGLE THAN THE ORIGINAL ONE ?
Tx
Raf
BFB
BFB is offline
PostPosted: Thu Mar 21, 2024 6:09 am    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
none know of but you could race prep the 90's and run wide rear track & as long of an axle as you can to decrease angle
Forced induction can overcome a lot of obsticles that gets in it's way
"You are the Engineer and the Mechanic.
Build it your way not the way someone else does it. Their way might not work for you." - clonebug
“ The monkey see monkey do mentality seems to run deep in VW people. "Gene Berg said it was so 30 years ago so thats the way it is" “ - bdkw1
petrol punk
petrol punk is offline
PostPosted: Thu Mar 21, 2024 7:59 am    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
In college I built a baja SAE buggy and used the original Type 1 CVs out of my 200k mile '70 bug at up to 25* IIRC. The issue with Type 1 CVs is that the boot is mounted on a metal ring that limits you to something like 12*. With a different boot design you have much less limitation for your CV angle. I think we 3D printed our own boots though so I don't have an off the shelf solution for you. Maybe look for a rzeppa joint CV boot you can just hose clamp to the OD of the CV housing?
36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma
DesertSasquatchXploration
DesertSasquatchXploration is offline
PostPosted: Thu Mar 21, 2024 1:21 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
Yea Noo you can get 15 out of 90mm CVs safely 18 they start to click and 20 the balls try to fall out. I recently re-indexed my torsion bars and notched the spring plates a little more have 17 now at full drop its maxed out. That's with real VW axles and CV joints, the rubber boots are not real happy. I'm expecting them to tear by the end of this riding season, will have to find a better aftermarket boot but that's next years problem.
BFB
BFB is offline
PostPosted: Thu Mar 21, 2024 3:39 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
Type 1 12*
Type 2 17*
Type 4 22*
930. 25*
These arent dead set numbers but pretty accurate from what ive messed with.
I have gotten 24 or 25 degrees ( don’t remember which ) out of race prepped type 4’s though.
74 Thing
74 Thing is online now
PostPosted: Thu Mar 21, 2024 6:44 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
http://www.blindchickenracing.com/How_to/CVJoints_Axles/cv_joints_101.htm
Make sure you clock them too:
https://californiaperformance.com/technical-tips/cv-clocking/
raphael BE
PostPosted: Fri Mar 22, 2024 1:29 am    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
Tx you all
No real "cheap" solution - was worth asking
Rgds
dirtkeeper
dirtkeeper is offline
PostPosted: Sat Mar 23, 2024 9:18 am    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
raphael BE wrote:
Tx you all
Rgds
It’s been so long since I did this but I have empi type 2 race cv’s that I get at least the 21 degrees that was advertised. I recently looked for these again and don’t find them for sale currently. But I have them and they may still be available
I recall them having a race type 1 that I think was supposed to get 19 degrees
raphael BE
PostPosted: Tue Mar 26, 2024 3:44 am    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
dirtkeeper wrote:
raphael BE wrote:
Tx you all
Rgds
Hi Dirt
Sorry not sure I understand what you mean Wink
Has empi ever made 90 mm CV that woudl allow a biger angle ?
Tx
74 Thing
PostPosted: Tue Mar 26, 2024 8:55 am    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
https://www.racereadyproducts.com/cv-joints/empi-934-cv-joints/
BFB
BFB is offline
PostPosted: Tue Mar 26, 2024 3:21 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
Those are 934’ not 90mm …
74 Thing
PostPosted: Tue Mar 26, 2024 4:04 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
My bad-you can just click on the CV joint tab on that web page then click on whatever 930 CV joint you want from the EMPI, to McKenzie's, to Pro-Am Racing. They have the specs. Or go to the EMPI website and look up the part number in the catalog for the description.
dirtkeeper
PostPosted: Wed Mar 27, 2024 2:42 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
raphael BE wrote:
dirtkeeper wrote:
raphael BE wrote:
Tx you all
Rgds
Hi Dirt
Tx
I specifically recall that they did but i cant find them currently and they may not make it anymore. But they deffinetly had type 2 cv's with more articulation because i have them. looking at some of the race cv's being sold now dont say much about angle so i am not sure they are the same thing.
Mikedrevguy
Mikedrevguy is offline
PostPosted: Thu Mar 28, 2024 7:19 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
[quote="dirtkeeper"][quote="raphael BE"]
dirtkeeper wrote:
raphael BE wrote:
Tx you all
Rgds
Dirt, These may be what you’re looking for.
https://a.co/d/3spiZtF
74 1303 (RevBug): plan for German Look
76 914 with 2260
79 VW Iltis
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
BFB
BFB is offline
PostPosted: Fri Mar 29, 2024 6:02 am    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
[quote="Mikedrevguy"][quote="dirtkeeper"]
raphael BE wrote:
dirtkeeper wrote:
raphael BE wrote:
Tx you all
Rgds
what kind of spam shit is that??
Mikedrevguy
PostPosted: Fri Mar 29, 2024 8:36 am    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
[quote="BFB"][quote="Mikedrevguy"]
dirtkeeper wrote:
raphael BE wrote:
dirtkeeper wrote:
raphael BE wrote:
Tx you all
Rgds
An Amazon link for T2 CVs?
76 914 with 2260
79 VW Iltis
69 Bwajaja
BFB
BFB is offline
PostPosted: Fri Mar 29, 2024 4:34 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
[quote="Mikedrevguy"][quote="BFB"]
Mikedrevguy wrote:
dirtkeeper wrote:
raphael BE wrote:
dirtkeeper wrote:
raphael BE wrote:
Tx you all
Rgds
Huh, wasnt when I clicked on the link.
Mikedrevguy
PostPosted: Sat Mar 30, 2024 7:16 pm    Post subject: Re: 90 mm Typ1 Cv Joint allowing more angle ? Reply with quote
My apologies for whatever link was connected. Do not know what’s up, as I get to the race prep t2cv from Amazon.
76 914 with 2260
79 VW Iltis
69 Bwajaja
