What are these holes in the beam?
Eric71sup
Eric71sup is offline
PostPosted: Sun Mar 24, 2024 4:58 pm    Post subject: What are these holes in the beam? Reply with quote
I'm completing the process of narrowing my beam. In the process of cutting, welding and grinding I no longer have the hole plugs for these 4 holes.
Do I need these holes? I can't find new plugs for them. Can I weld them in?
66’ Beetle (in process)
71' Super Convertible
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Mar 24, 2024 5:00 pm    Post subject: Re: What are these holes in the beam? Reply with quote
Grease fittings
Glenn
Member #1009
#BlueSquare
Eric71sup
PostPosted: Sun Mar 24, 2024 5:18 pm    Post subject: Re: What are these holes in the beam? Reply with quote
I've got 4 grease fittings further out closer to the end supports. These holes had plastic stoppers in them. I should have taken the time to pull them out but instead I got grinder happy.
KTPhil Premium Member
KTPhil is offline
PostPosted: Sun Mar 24, 2024 7:08 pm    Post subject: Re: What are these holes in the beam? Reply with quote
Locknut/access/visual check for stop for torsion arm bushings?
Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback
Busstom
Busstom is offline
PostPosted: Sun Mar 24, 2024 7:18 pm    Post subject: Re: What are these holes in the beam? Reply with quote
Why not just weld'em up then?
Oh yeah, that's what you want to do Very Happy
My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏
Eric71sup
PostPosted: Mon Mar 25, 2024 4:53 am    Post subject: Re: What are these holes in the beam? Reply with quote
I think that is my course of action. I wanted to see if anyone knew anything about them before I welded them in permanently.
esde
esde is offline
PostPosted: Mon Mar 25, 2024 5:24 am    Post subject: Re: What are these holes in the beam? Reply with quote
What is the beam for? I do not recognize the bracket on the left of the pic.
My best guess is that it was intended to be a drain. Fresh grease forces the old grease towards the center and with it goes any contaminants. Occasionally when building a beam I found one with lots of rust inside the tube near the center, where water was trapped and just sat.
modok wrote:
Busstom
Busstom is offline
PostPosted: Mon Mar 25, 2024 8:40 am    Post subject: Re: What are these holes in the beam? Reply with quote
Those are the center adjuster brackets.
aviator8
aviator8 is offline
PostPosted: Tue Mar 26, 2024 3:09 pm    Post subject: Re: What are these holes in the beam? Reply with quote
I had the same question. I never got a solid answer, but best guess is a weep hole to allow any moisture that got int the beam to get out.
https://www.thesamba.com/vw/forum/viewtopic.php?t=767004&highlight=
KTPhil is offline
PostPosted: Tue Mar 26, 2024 3:15 pm    Post subject: Re: What are these holes in the beam? Reply with quote
Maybe exit holes to ensure no big air pockets on first greasing? Then plug with threaded or rubber plugs?
Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback
Eric71sup
PostPosted: Tue Mar 26, 2024 6:05 pm    Post subject: Re: What are these holes in the beam? Reply with quote
I appreciate the answers. They are now full of weld. I'll let you know in 30 years if I made a mistake.
Busstom
Busstom is offline
PostPosted: Tue Mar 26, 2024 7:36 pm    Post subject: Re: What are these holes in the beam? Reply with quote
I'll be dead, but your beam will be okay Wink
