OldJPLer Samba Member
Joined: March 24, 2024 Posts: 2 Location: Pasadena,CA
Posted: Sun Mar 24, 2024 5:13 pm Post subject: Gray Water Tank Simple For Vanagon Westie |
I got tired of the Rangers complaining about my external yellow gray water bucket. Some approved, some didn't.
Cheap effective and internal is what works for me. No $400 external tanks. A $5 2.5 gal water jug is my style. I think it fits and looks pretty good.
The stock drain hose with a cutout in the shelf above is all you need.
I conserve water anyway and when the tank gets almost full, I slide it out and empty it.
E1 Samba Member
Joined: January 21, 2013 Posts: 6606 Location: Westfalia, Earth
Posted: Sun Mar 24, 2024 5:26 pm Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
You may or may not realize it’s possible to travel and camp while cooking typical home meals and still not generating any gray water at all.
Our worst-case kettle cleanups are done with an ounce or two of water max., that then ends up in paper towels and in the trash. We haven’t carried dish soap for years, and need a scrub pad only if we screw up. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
bobhill8 Samba Member
Posted: Sun Mar 24, 2024 6:00 pm Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
Nice simple solution. Thanks for sharing. _________________ 1986 Westy
1971 Squareback |
Andymon Samba Member
Joined: February 24, 2015 Posts: 314 Location: Medford, OR
Posted: Mon Mar 25, 2024 8:46 am Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
We have this. The hose we have connects to the drain tube from the sink and then to the grey water bag.
_________________ "Blanch" '85 Westy
"Too many freaks and not enough circuses". |
Posted: Mon Mar 25, 2024 10:35 am Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
Thanks for the cool responses.
I'll post more simple ideas that have helped me when camping over the last 50 years...
Like: Finding extra storage, cooking on my Buddy heater, adding a radiator fan override switch, simple solar charging, night sky port and insulating the ice box (aka latrine?).
Shannon Jackson
1984 Westfalia with Subaru EJ22 |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4099 Location: East Kootenay, British Columbia
Posted: Mon Mar 25, 2024 2:28 pm Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
https://www.busdepot.com/255070814c
Just fyi - $180, not $400, and you don't lose any internal storage space or spillage.
Available for A/C equipped or not. (a/c hose route)
These are easy to drain/flush and really tough.
I understand a cheap option is sometimes required, but having the real thing has advantages. Just wanted to clarify the price. _________________ Currently:
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17158 Location: Retired South Florida
Posted: Mon Mar 25, 2024 7:04 pm Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
We don’t have that space in the cabinet, but to those that use an external temp solution, I’d recommend a lanyard to attach it to the front jack point when deployed. This will keep you from driving over it when you get in a hurry and forget. Speaking from experience. _________________ ☮️ |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Tue Mar 26, 2024 7:10 am Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
Good old thread on DIY gray water tanks. Still happy with my hack.
https://www.thesamba.com/vw/forum/viewtopic.php?t=412565&start=40 _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1091 Location: Atlanta, GA
Posted: Tue Mar 26, 2024 3:17 pm Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
I've been using the same setup that Andiron shows in his pic. It was $6 at Walmart, and a short garden hose extender that screws on to the pipe on the Westy. Works like a charm. I can see when it needs to be emptied. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Westified Samba Member
Posted: Tue Mar 26, 2024 5:49 pm Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
I have this solution. Very compact. It connects to the drain under the van. Put a note on.your steering wheel so you don’t drive off with it attached, like Mark said. It is very durable and compact.
https://www.peacevans.com/metris-accessories/external-grey-water-tank?rq=Grey%20water
Regarding, what MsTaboo said regarding the BusDepot grey water tank. That is a nice solution I wanted but I have Air Conditioning. My AC hoses under my van block where I can mount the grey water tank by Busdepot, even with the AC specific grey tank. That is due to the fact my AC hoses run under the frame at that point, instead of through the frame. It depends on what year van you have with AC. Check under your van in front of the propane tank. If your AC hoses go through the frame you can order the grey water tank for vans with AC. _________________ 1984 Westy Wolfsburg, owned since 1987. FAS 2.0 NA engine conversion in 2022. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Wed Mar 27, 2024 10:54 am Post subject: Re: Gray Water Tank Simple For Vanagon Westie |
Westified wrote: |
Regarding, what MsTaboo said regarding the BusDepot grey water tank. That is a nice solution I wanted but I have Air Conditioning. My AC hoses under my van block where I can mount the grey water tank by Busdepot, even with the AC specific grey tank. That is due to the fact my AC hoses run under the frame at that point, instead of through the frame. It depends on what year van you have with AC. Check under your van in front of the propane tank. If your AC hoses go through the frame you can order the grey water tank for vans with AC. |
I just re-routed the A/C hoses to go through the frame - easy enough to do, as long as you're happy with re-charging the A/C. Using Envirosafe that only cost about $15, so no problem. ISTR that I had to drill an extra hole for one of the hoses, but a step drill bit took care of that. _________________ Jim Crowther
Vespa GTS 300 |
