bmoehring Samba Member
Joined: March 26, 2005 Posts: 203 Location: Pinckney, MI
Posted: Mon Mar 25, 2024 1:57 pm Post subject: Rear seat panel |
Hi -
The enclosed photos show a carpeted panel included some years ago in my 73 Beetle. I'm at a loss as to where it goes.
There are no mounting holes, the edges have those hard strips sewn to it, and it has the rear seat strap ferrule in the center.
I've always assumed this is a parcel shelf of some kind.
[/img] _________________ 73 sedan
72 Westy non pop-up |
talljordan Samba Member
Joined: January 10, 2012 Posts: 978 Location: San Francisco, CA
Posted: Mon Mar 25, 2024 2:41 pm Post subject: Re: Rear seat panel |
This is the back side of the rear seat, the top part (seat back). Its there so that when you fold the seat back down, you can put your luggage on it. Its held on with two metal strips that are screwed into the seat frame.
I believe yours may be aftermarket or damaged? It doesnt look like the right shape to me, but I havent seen many stock ones.
Also on a personal note, can you measure how far from the edge that metal grommet is? Im currently making a new one of these for my own car, and Im not sure where that grommet is supposed to be in the plate. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Wanted: Male computer diagnostic plug end |
Posted: Mon Mar 25, 2024 6:57 pm Post subject: Re: Rear seat panel |
[quote="talljordan"]This is the back side of the rear seat, the top part (seat back). Its there so that when you fold the seat back down, you can put your luggage on it. Its held on with two metal strips that are screwed into the seat frame.
Most assuredly not the back of a sedan rear seat. That piece was sitting off to the right, out of the picture.
This piece is nothing like the seat back. _________________ 73 sedan
Posted: Mon Mar 25, 2024 10:02 pm Post subject: Re: Rear seat panel |
The seat back backing plate is made of two pieces. A piece that covers the back luggage area, and a piece that covers the back of the seat.
This is the piece that covers the back of the seat, you can tell cause it has the exact metal grommet. WW sells these and shows a diagram.
Dont believe me if you dont like, but thats the answer. _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
BMFBMF Samba Member
Joined: November 13, 2020 Posts: 358 Location: Swtzerland
Posted: Tue Mar 26, 2024 2:43 am Post subject: Re: Rear seat panel |
+1 _________________ -----Slava Ukraini-----
1971 Stock South African Beetle 1300 : My mom's european "Thin Chick" spec. Completely stock with torsion bar front, swingaxle rear, smooth hubs, single MC, 40 mm shoes, 31PICT3 carb and 5 bolt drums all round, currently Running a 1976 SF:AS engine with the original SF:AD engine overhauled in a box, waiting to go back in one day. |
baldessariclan Samba Member
Joined: October 14, 2016 Posts: 1385 Location: Wichita, KS
Posted: Tue Mar 26, 2024 6:28 am Post subject: Re: Rear seat panel |
Yeah, believe it's part of the 2-piece seat back/shelf system used in later Beetles, like talljordan was talking about. There's a few pics of the setup shown in this thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=9571267&highlight=#9571267 _________________ 1971 Standard Beetle — fairly stock / driver
baldessariclan -- often in error, never in doubt... |
Posted: Wed Mar 27, 2024 8:55 am Post subject: Re: Rear seat panel |
In all my searches for "parcel", "shelf", or "parcel shelf", none of this showed up. Not sure why.
At any rate, the piece I pictured must have been thrown in the car at some point as there are no witness marks or holes for the two, thin fabric straps shown in post #9571267. This piece is quite flimsy, actually.
I'll search through later T1 literature to find more.
Thanks! _________________ 73 sedan
Posted: Fri Mar 29, 2024 9:26 am Post subject: Re: Rear seat panel |
It's flimsy cause it's fully supported by the cross bars on the rear seat back. This piece is the cover for the rear seat backrest. The parcel tray is thicker.
Jbugs has a video showing rear seat restoration where they show how to manufacture one of these from scratch _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Fri Mar 29, 2024 3:01 pm Post subject: Re: Rear seat panel |
Ok, so..... what do I have here, is this seat back for a 73, or earlier?
The clue was to look at Jbugs site, and there I see different graphic depictions of rear cargo carpet kits for 72-earlier, and 73-77. Other sites are not as clear.
The piece I pictured originally is lying next to the seat back. _________________ 73 sedan
Posted: Fri Mar 29, 2024 3:13 pm Post subject: Re: Rear seat panel |
Well Ill be damned. The my sense of scale was off in the initial image.
In this image, I thought the object on the left was the object on the right. This doesnt quite make sense to me, maybe someone cut up a seat back? _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Fri Mar 29, 2024 6:16 pm Post subject: Re: Rear seat panel |
In this image, I thought the object on the left was the object on the right. This doesnt quite make sense to me, maybe someone cut up a seat back?[/quote]
Exactly, it just doesn't seem to fit anything around the rear seat.
Maybe not even for a beetle ?
Additionally, the cargo area carpet kit I bought does not fit the seat, the shape is wrong for the seat back, or the seat is wrong for the car. _________________ 73 sedan
Posted: Fri Mar 29, 2024 6:27 pm Post subject: Re: Rear seat panel |
Which carpet kit did you purchase, the aftermarket ones are a bit non intuitive. Once again Id suggest watching the JBugs video.
My best guess on that panel is someone chopped up a panel (like the one you have on the right) _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9977 Location: Huntington Beach, CA
Posted: Fri Mar 29, 2024 10:28 pm Post subject: Re: Rear seat panel |
I documented my OG rear seat from one of my 70 Bugs. Page 2, half way down. There are more pictures in my gallery, I think. Might be worth a look!
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20 _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sat Mar 30, 2024 7:52 am Post subject: Re: Rear seat panel |
Yes, looks just like mine, I'd say! _________________ 73 sedan
Posted: Sat Mar 30, 2024 11:01 pm Post subject: Re: Rear seat panel |
bmoehring wrote: |
Yes, looks just like mine, I'd say! |
That smaller piece gets attach to the rear seat back, down low. It then stretches over to the “J” channel at the rear luggage shelf.
So, when you pull the seat back down, after removing the bottom, this piece forms a “bridge” between the seat back and the luggage self.
Hope that seems clear. _________________ Jimbo
TDCTDI wrote: |
Posted: Sun Mar 31, 2024 7:09 pm Post subject: Re: Rear seat panel |
Jimbo this was very helpful for my project as well. I am still struggling to understand how to properly route the cable through the metal grommet though, and how it holds the seat down. Why the grommet hole is on the bottom side of the seat back escapes me.... _________________ 1972 Super Beetle, Parked until adequate restoration funding is acquired in restoration!
Posted: Sun Mar 31, 2024 7:49 pm Post subject: Re: Rear seat panel |
[/quote]
Hope that seems clear.[/quote]
I thought that's what the gap seal was for, pictured here. Yes?
Posted: Sun Mar 31, 2024 7:53 pm Post subject: Re: Rear seat panel |
And another thing; the owner's manuals talk of the luggage area cover being a hinged piece to the seat back. I have no evidence of anything like that on my seat, and have yet to see details or restoration parts for this. _________________ 73 sedan
Posted: Mon Apr 01, 2024 10:35 am Post subject: Re: Rear seat panel |
bmoehring wrote: |
And another thing; the owner's manuals talk of the luggage area cover being a hinged piece to the seat back. I have no evidence of anything like that on my seat, and have yet to see details or restoration parts for this. |
The “hinge” is just the cover secured to the seat back. It is “hinged” onto the seat back. Meaning its position changes as the seat back lowers and raises. That carpet bridge is one leaf of the hinge. The seat back is the second leaf. And the pivot is the attachment point at the lower seat back, under the steel overlay. A “hinge” in a sense.
From the Dictionary. Remember those!
“Definitions from Oxford Languages · Learn more
hinge
noun
a movable joint or mechanism on which a door, gate, or lid swings as it opens and closes or which connects linked objects.”
Hope that helped.
I have never seen an aftermarket kit with that done correctly! _________________ Jimbo
TDCTDI wrote: |
Posted: Mon Apr 01, 2024 11:23 am Post subject: Re: Rear seat panel |
Yes, I am aware of how the pictured pieces assemble.
I'm also still looking for information concerning the hinged cover over the luggage area, as mentioned in the owner's manual. There is some hinged, hard, and I'm assuming carpet-covered, piece from the top of the rear seat to the spot under the rear window.
Pull the seat back forward slightly, bring this cover up from the stowed position (I'm assuming laying against the back of the seat), then set it in that slight shelf spot under the rear window as you move the seat rearward, back into position.
It bridges the area from top of the rear seat to the rear window. _________________ 73 sedan
