KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Mon Mar 25, 2024 3:43 pm Post subject: Cable from shroud thermostat arm to air cleaner flap? |
I have a later engine in my '69 Bus, with the doghouse shroud/fan and a working thermostat.
The shroud it came with lacked the little lever on the right side to link to the stock air cleaner. I bought a new flap box with the external lever and installed it. The little lever is pretty well hidden behind the dual port intake manifold. It's plain strip of metal.
I am also not 100% sure my air cleaner is a perfect match. It has a little dogleg operating rod on a warm air flap.
I'll get photos to help y'all help me; but I'm not sure just what cable style and routing are called for with this stock (but unknown year) setup.
Anyone got photos of the proper cable & linkage? (Assuming my hardware is "proper") _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76970 Location: Sneaking up behind you
KTPhil Samba Member
Posted: Mon Mar 25, 2024 3:47 pm Post subject: Re: Cable from shroud thermostat arm to air cleaner flap? |
Thanks, I'll check those out! _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
timvw7476 Samba Member
Posted: Mon Mar 25, 2024 3:52 pm Post subject: Re: Cable from shroud thermostat arm to air cleaner flap? |
when it comes to an actual actuator cable I just throw a Shimano bicycle cable, the kind used on index-shifting mountain/road bikes on there.
It's been a decade + since my last 'life/bus hack' on my '76. The air shutters can't tell the difference apparently. So far, so good. It's a multi-strand steel cable. What could possibly go wrong . ? You might need a cable retainer barrel similar to what VW used on the heater boxes, but one that features an E-clip end to lock on to the lever/arm you mentioned. Specialized hardware. Someone must make it. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51173 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Mar 25, 2024 3:57 pm Post subject: Re: Cable from shroud thermostat arm to air cleaner flap? |
Someone makes the proper part now, Awesomepowdercoat maybe? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
wcfvw69 Samba Purist
Posted: Mon Mar 25, 2024 8:31 pm Post subject: Re: Cable from shroud thermostat arm to air cleaner flap? |
I have an original VW bowden cable that hooks to the arm on the flap then routes to the arm on the oil bath. I'd be willing to sell it if you're in need.
Also, some folks replace that oil bath with a 71 bus oil bath with the thermostat in it. No linkage needed. _________________ Contact me at [email protected]
The Samba member since 2004.
wrxnofx Samba Member
Joined: July 06, 2022 Posts: 228 Location: Richfield, MN
Posted: Tue Mar 26, 2024 7:46 am Post subject: Re: Cable from shroud thermostat arm to air cleaner flap? |
busdaddy wrote: |
Someone makes the proper part now, Awesomepowdercoat maybe? |
That place is great! They have the cables, the thermostats, the coupling nuts, the brackets, the clips for the cooling flaps, the whole smash. _________________ 1977 VW Type 2 Bay Window Westy FI |
KTPhil Samba Member
Posted: Tue Mar 26, 2024 8:13 am Post subject: Re: Cable from shroud thermostat arm to air cleaner flap? |
busdaddy wrote: |
I think that's where I got the correct flap box. Great quality part! _________________ Current Fleet:
'71 Fastback
'69 Westfalia
Retired:
'67 Beetle
'65 Beetle (x2)
'65 Bus
'71 Squareback |
