edhnb Samba Member
Joined: December 02, 2011 Posts: 229 Location: El Dorado Hills, California
Posted: Wed Mar 27, 2024 9:08 am Post subject: Engine installation - Fuel Injected |
I am getting to the point where I will be putting the engine back in the bus in a couple days. I am just re-assembling powder coated engine tins, intake, etc...
My question is, what type of things should be put back on the engine before installation vs after to make the actual installation easier?
Example: is it easier to put the injectors/rails/hoses on before the engine goes in, or does that stuff hinder installation? Same question for alternator, etc..
Basically, how do I make this process easier on myself?
Thanks,
Nick _________________ 1977 Asi Riviera |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12729 Location: on a bike ride somewhere
Posted: Wed Mar 27, 2024 9:30 am Post subject: Re: Engine installation - Fuel Injected |
Are you installing the engine and transaxle together? I hope so; it's so much easier. If so, leave the starter off, and carefully guide the heater control pods around the chassis as you go. I find loosening the 17mm transmission hanger mounts helps get the bellhousing ears into the hanger easier for the 15mm pointy-tipped bolts. Having a helper and an extra jack to raise/lower the powertrain really helps get those bolts aligned. Don't forget to tighten the 17's after.
I install everything except the coil and oil filler, putting tape over the oil fill pipe. The s-boot has to stay off anyway, to get the long starter bolt threaded into the 17mm nut.
The individual fuel injector hoses should be cut short enough that the injectors do not protrude past the tin. Make sure the fuel clamps on all hoses around the firewall/fuel pressure regulator are accessable with the engine installed later.
Good luck!
www.airschooled.com |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16976 Location: San Diego, California
Posted: Thu Mar 28, 2024 10:43 pm Post subject: Re: Engine installation - Fuel Injected |
The way we do it is a complete engine minus the oil filler plastic neck and of course the airbox and S duct mated to the tranny. Easier to get the tranny hanger bolts in without the starter yet. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Mar 29, 2024 6:30 am Post subject: Re: Engine installation - Fuel Injected |
Since I typically pull the engine by itself, I leave off the coil, the oil filler extension, and the left rear piece of tin. |
edhnb Samba Member
Posted: Fri Mar 29, 2024 9:34 am Post subject: Re: Engine installation - Fuel Injected |
Perfect. Thanks for the replies. It's going in today hopefully... _________________ 1977 Asi Riviera |
edhnb Samba Member
Posted: Sat Mar 30, 2024 5:03 pm Post subject: Re: Engine installation - Fuel Injected |
Is it a better idea to install the alternator while the engine is out, or just do it once I have the engine installed? It seems I have to get behind it either way once the engine is in to hook up the wiring. _________________ 1977 Asi Riviera |
Posted: Sat Mar 30, 2024 5:08 pm Post subject: Re: Engine installation - Fuel Injected |
edhnb wrote: |
Is it a better idea to install the alternator while the engine is out, or just do it once I have the engine installed? It seems I have to get behind it either way once the engine is in to hook up the wiring. |
The alternator and its wiring harness can, and should, be installed with the engine out. I don't think you can install the alternator harness with the alternator installed in the car…
edhnb Samba Member
Posted: Sat Mar 30, 2024 5:30 pm Post subject: Re: Engine installation - Fuel Injected |
I thought about that after I posted and then went and found my wiring harness, so that is the plan.
Thanks _________________ 1977 Asi Riviera |
Posted: Sat Mar 30, 2024 5:43 pm Post subject: Re: Engine installation - Fuel Injected |
edhnb wrote: |
Thanks |
No problem.
If you have a new alternator, make sure the magic smoke doesn't come out.
https://www.thesamba.com/vw/forum/viewtopic.php?t=615013
If you reinstalling your old one, carry on.
wrxnofx Samba Member
Joined: July 06, 2022 Posts: 227 Location: Richfield, MN
Posted: Sun Mar 31, 2024 8:52 am Post subject: Re: Engine installation - Fuel Injected |
airschooled wrote: |
edhnb wrote: |
Robbie |
I’ve done it with the engine in. It’s not too bad. Heat exchangers were in, too. That being said, it’s WAY easier with the engine out and that’s how I’d do it. It’s not like having it in inhibits putting the engine back in. _________________ 1977 VW Type 2 Bay Window Westy FI |
edhnb Samba Member
Posted: Sun Mar 31, 2024 9:13 am Post subject: Re: Engine installation - Fuel Injected |
edhnb wrote: |
Thanks |
No problem.
Robbie |
Yep. I read that post. It is a new rebuilt bosch. I'm making the gasket and making sure everything is protected as we speak. I'm also thinking about actually modifying the back cover tin to make more room for the nut that just about touches the edge. I'll post some pictures in that thread. _________________ 1977 Asi Riviera |
Posted: Sun Mar 31, 2024 4:44 pm Post subject: Re: Engine installation - Fuel Injected |
On my old T4, I used a step drill to make a 1" hole directly over the stud, and used a 1" rubber hole plug (like a grommet) to fill the hole. Still keeping the insides dry, but if I ever needed to swap an alternator on a trip, it would clear the backing plate.
