Yannvanh Samba Member
Joined: November 07, 2020 Posts: 143 Location: Belgium
Posted: Fri Mar 29, 2024 1:18 am Post subject: Bay window irs on splitty |
I am doing a bay window irs conversion on my 66 splitbus
Earlybay parts are necessary but really hard to find so i am using layte bay parts (modify the control arms and spring plates myself)
You can buy early bay stub axle brand new and it would be ideal if i can fit a 5x205 earlybay drum but do the earlybay stub axle fit in my late bay bearing house? I think the bearings themself are different ( gonna buy new bearings anyway) but the late bay has some sort of spacer in the housing between the bearings that i think a early one doesn't has..
Does anyone has the same setup or knows i it will fit?
Thanks in advance! _________________ '66 vw splitbus project:
Instagram page:
yannicks_splitbus_project
Always there to help! |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12413 Location: Over 2002 posts deleted!
stevecul8er Samba Member
Joined: October 05, 2006 Posts: 100 Location: Honolulu,Hawaii
Posted: Fri Mar 29, 2024 8:12 pm Post subject: Re: Bay window irs on splitty |
If you go back to the “IRS Bracket” thread that you started is some useful information. Although creative-engineering.com is not selling the parts anymore-you can download the catalog and browse the their IRS conversions and parts used and get an idea what would work for you so you proceed with your conversion.
Good luck |
Posted: Tue Apr 02, 2024 7:08 am Post subject: Re: Bay window irs on splitty |
Yeah i bought the CE frame legs so my question whas if there i could use the 68-69 stub axle in my 70- bearing holder so i could fit the 5x205 brake drum _________________ '66 vw splitbus project:
Instagram page:
dtadpole Samba Member
Joined: November 15, 2012 Posts: 85 Location: Southern Illinois
Posted: Wed Apr 03, 2024 7:15 am Post subject: Re: Bay window irs on splitty |
If I am not mistaken I don't think the 68-69 drive shafts will fit the 70-80 hubs. I think you have to use the 68-69 hubs since they are longer. I had a heck of a time to find the hubs and assemblies. I ended up getting a set shipped to my house in different boxes usps lost one and I got the other. I then ended up buying 2 CE- arms from jeffgagnon here on the samba and another 68-69 hub from someone else with stub axle also.
jeffgagnon maybe able to help you with this also. _________________ 1965 velvet green walk-thru standard
scrappythebus.com
https://youtube.com/@dtadpole |
Posted: Thu Apr 04, 2024 7:36 pm Post subject: Re: Bay window irs on splitty |
Providing your hub does not have the “C” clip to hold the outer bearing -you use the same inner bearing,spacer, new outer (211501283D) bearing and a13 mm spacer.
As for the control arms-use the 68-70 Bay (440MM long) later bays are 420mm,
The drive shafts 476MM with bus cv on one end and bug cv on other end.
Again go research the creative-engineering.com site catalog section-after all you using some of their parts.
Mismatching parts causes more headaches. I’ve been there.
Good luck. |
richierich Samba Member
Posted: Fri Apr 05, 2024 6:10 am Post subject: Re: Bay window irs on splitty |
I have this conversion in the rear of my 57 panel. I have early bay drive shafts and 71 only hubs which use 71-79 wheel bearings. Bay CV's at hub end and bug CV's at trans end.
Hope that helps a little. _________________ Blah..... |
