davisshannon Samba Member
Joined: January 06, 2024 Posts: 103 Location: Melbourne, Australia
Posted: Fri Mar 29, 2024 10:37 pm Post subject: Dropped spindles with 4” narrowed beam tire size |
I’ve looked through lots of posts but can’t decide on a front tire size.
I’ve got drop spindles and a 4” narrowed adjustable beam. I’ve also bought some 15x5.5 Superspeed wheels from Cip1 (https://www2.cip1.com/c32-ss5205-5515-sb/).
I’d like to keep a bit of width for bigger contact patch.
Stock smoothies with 165/80r15’s rub pretty quickly on the headlight buckets.
Would 175/60r15’s be too risky? Would 165/60r15’s be safer, or am I going to need to go even narrower?
Thanks |
NJ John Samba Member
Joined: September 21, 2007 Posts: 3034 Location: HdG, MD & NJ
Posted: Sat Mar 30, 2024 12:58 pm Post subject: Re: Dropped spindles with 4” narrowed beam tire size |
I keep hearing that the 175/60’s are too wide. But, maybe someone will chime in with actual experience. How low are you? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Posted: Sat Mar 30, 2024 2:39 pm Post subject: Re: Dropped spindles with 4” narrowed beam tire size |
| I’m sitting pretty low right now. I’m actually having trouble getting my adjustable beam adjusted higher. I’ll try to get it adjusted up a bit and see if that makes a difference. |
Posted: Sun Mar 31, 2024 1:16 am Post subject: Re: Dropped spindles with 4” narrowed beam tire size |
| I’ve ordered some 175/55r15’s and will see how they go. |
Posted: Wed Apr 03, 2024 9:47 pm Post subject: Re: Dropped spindles with 4” narrowed beam tire size |
Ok, got my wheels and tyres on. But beam shifted loosened a tad when moving, so back up on the jack stands tomorrow to fix that up.
175/55r15 Bridgestone Potenzas up front
185/65r15 Bridgestone Ecopias (all they had) in the rear
CIP Super Speeds 15 INCH X 5.5 INCH WIDE - (BACKSPACING 3.80INCH ET+14) 5 BOLT X 205MM
I’ll play with the stance a bit most likely. Front is at about 115mm at the lowest point.
Teeroy  Samba Member
Joined: April 20, 2003 Posts: 3899 Location: Eastern WA
Posted: Thu Apr 04, 2024 4:05 pm Post subject: Re: Dropped spindles with 4” narrowed beam tire size |
They rub headlight buckets from the height, not the width. I would try to raise it some more than pictured. Get the sidewall to fender height closer to what you have in back. Will still have rake but look a little more balanced _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Posted: Thu Apr 04, 2024 5:16 pm Post subject: Re: Dropped spindles with 4” narrowed beam tire size |
Nice stance! _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
