Prawnabie Samba Member
Posted: Wed Apr 03, 2024 7:53 am Post subject: Major restoration, what order for body repairs...? |
Hi all,
The 67 I have acquired needs major repair work, basically the bottom 6" of the car is rotten. I have the body braced and have am sorting the frame head/naps hat/tunnel first so I can at least get the body back on temporarily.
Once I have the body back on, I will be tackling the following..
Floors
Heater channels
front inner wing lowers
lower a posts (door bottoms will need doing at some point too)
front and rear cross members
What order would you recommend I do this it? I have a sort of idea but the heater channels and floors are a bit chicken and egg at the moment (I have no floors in there to measure).
Can anyone offer any guidance?
Thanks |
RLFD213 Samba Member
Posted: Wed Apr 03, 2024 12:52 pm Post subject: Re: Major restoration, what order for body repairs...? |
Brace the body first, then do the floor pans so you have a foundation to put the no post back on. Then do the body stuff: heater channels, etc |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Wed Apr 03, 2024 3:44 pm Post subject: Re: Major restoration, what order for body repairs...? |
Start from the inside out - check the control cable and fuel tubes that run inside the chassis. Be sure the heater channel and floor fasteners all line up.
Don't throw anything away until the new parts are known to fit. That old rusty stuff still has geometric value.
Don't forget the 5 drain hole grommet/valves after you've painted the bottom. _________________ 1972 Standard Beetle
1969 Baja Beetle |
esde Samba Member
Joined: October 20, 2007 Posts: 5979 Location: central rust belt
Posted: Wed Apr 03, 2024 5:52 pm Post subject: Re: Major restoration, what order for body repairs...? |
floors and heater channels first, and together so you are sure the bolt holes align. Then do your a pillars, and inner wheel wells, then rear crossmember
Every step of the way double check your door alignment, as every repair you face can change it _________________ modok wrote:
Posted: Fri Apr 05, 2024 2:43 am Post subject: Re: Major restoration, what order for body repairs...? |
Thanks, I guess one of the first jobs is to sort the hinge pins out then! |
