kamkaz Samba Member
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1479 Location: Westfield, MA.
Posted: Mon Apr 08, 2024 10:35 am Post subject: Re: Reverse grinding and 1st difficult to engage |
Have you checked the shift plate at the tunnel? Bolts loose? I would start with readjusting it and see what happens. Also wouldn't hurt to check on the shift coupler under the rear seat and the shift rod bushing in the tunnel. |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4858 Location: sanger ca
Posted: Mon Apr 08, 2024 10:42 am Post subject: Re: Reverse grinding and 1st difficult to engage |
Clutch is dragging, if it goes into gear easy with the engine off you clutch is dragging. Reverse has no synchro so it grinds, first does have a synchro. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
modok Samba Member
Joined: October 30, 2009 Posts: 26797 Location: Colorado Springs
Posted: Mon Apr 08, 2024 10:41 pm Post subject: Re: Reverse grinding and 1st difficult to engage |
I think you answered your own question here, although actually you didn't ask a question.
kamkaz wrote: |
* 2 Days ago I noticed the clutch engagement point started to feel a bit low. Similar to the time that the clutch slave cylinder failed.
kamkaz Samba Member
Posted: Thu Apr 11, 2024 1:30 pm Post subject: Re: Reverse grinding and 1st difficult to engage |
Update: I was able to make the reverse grinding go away by doing a 1/8 turn on the wing nut that is on on clutch slave. The engagement point is still low.
The clutch slave is only a 500 miles old and there is no leaks from it or the master.
I'm starting to think it's air in the line. |
kamkaz Samba Member
Posted: Thu Apr 11, 2024 1:32 pm Post subject: Re: Reverse grinding and 1st difficult to engage |
MuzzcoVW wrote: |
I'm using a cable shifter. Pictures are linked. |
Posted: Thu Apr 11, 2024 1:48 pm Post subject: Re: Reverse grinding and 1st difficult to engage |
kamkaz wrote: |
MuzzcoVW wrote: |
Sorry, pics not working on this end |
kamkaz Samba Member
Posted: Thu Apr 11, 2024 9:45 pm Post subject: Re: Reverse grinding and 1st difficult to engage |
Sorry, here it is:
nsracing Samba Member
Posted: Mon Apr 15, 2024 3:07 am Post subject: Re: Reverse grinding and 1st difficult to engage |
Oh we get it - your new ride? You have a name Kammy?
Looks like the ride just got off the showroom.
He has 5 posts - you guys. Why not welcome him to the forum properly. |
