Gezz Samba Member
Joined: December 09, 2022 Posts: 11 Location: South Florida
Posted: Wed Apr 17, 2024 8:07 am Post subject: surging, backfiring |
so friend has a 78 bus with single 2 barrel weber, electric fuel pump and a combination fuel filter/regulator with glass bowl. Bus was running perfect until filled up and then started missing/surging. I looked at it and the fuel filter was clogged. Changed the filter and it ran great for about 30 minutes and then same thing occurred. Went back and found water in the gas in filter. Drained out all the gas, put in fresh gas, now problem remains, barely running. Has me stumped? pulled the weber filter and it is clean. Bad pressure regulator, pump tested and it is fine. thanks for any help here. _________________ Beachside Mechanic
69 Double Cab
73 Thing
2015 New Beetle Convertible |
dodger tom Samba Member
Joined: March 25, 2013 Posts: 1273 Location: Central Coast, CA, but we're all still Ukrainian
Posted: Wed Apr 17, 2024 8:16 am Post subject: Re: surging, backfiring |
try adding a bottle or two of heet. that cured my water-in-the-gas problem. _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
timvw7476 Samba Member
Posted: Wed Apr 17, 2024 12:00 pm Post subject: Re: surging, backfiring |
& the fuel filter? If it is paper/fiber element, the water that ran in swells the fibers. Choking off flow, maybe forever. New element when a load of water is in the tank. : ( |
Gezz Samba Member
Posted: Wed Apr 17, 2024 4:02 pm Post subject: Re: surging, backfiring |
filter was replaced and all the old gas purged from the tank, thanks. _________________ Beachside Mechanic
69 Double Cab
73 Thing
aeromech Samba Member
Joined: January 24, 2006 Posts: 16982 Location: San Diego, California
Posted: Wed Apr 17, 2024 5:25 pm Post subject: Re: surging, backfiring |
Gravity feed the carburetor from an external fuel tank and see what happens _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Gezz Samba Member
Posted: Thu Apr 18, 2024 8:59 am Post subject: Re: surging, backfiring |
I did plan on eliminating the filter/regulator, checking the pressure output on the pump (which I know works as I used it to empty the tank) and if the pressure is below 3, hook it temporarily to the carb directly. Gravity feed may be easier and quick diagnostic. thanks for the advice _________________ Beachside Mechanic
69 Double Cab
73 Thing
Xevin Samba Member
Posted: Thu Apr 18, 2024 11:59 am Post subject: Re: surging, backfiring |
That carburetor is known to be sensitive to very fine dust. I would take the carb apart and blow out every orifice. It worked for me. Are you familiar with cleaning carburetors? I probably have some info saved if you need. I like to have a spare gasket on hand or just replace the gasket when I pull a carb. It doesn’t take long to pull off, disassemble, clean, and reinstall,,,,,the second time you do it _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Gezz Samba Member
Posted: Fri Apr 19, 2024 6:31 am Post subject: Re: surging, backfiring |
Yes, have rebuild thousands of carbs, it was also on my mind that something could have reached the carb. The regulator filter was really badly fouled with crud. Not sure how good the little brass mesh filter is inside the carb. thanks _________________ Beachside Mechanic
69 Double Cab
73 Thing
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2750 Location: Hamble, Hampshire, UK
Posted: Sat Apr 20, 2024 5:33 am Post subject: Re: surging, backfiring |
Maybe worth taking the carburettor off and emptying fuel and water out of it. Especially the power valve well under the fitting in the bottom of the float chamber, and pump the accelerator repeatedly to clear the accelerator pump..
We always used to have trouble buying gas for outboard motors from a local marina because it rained regularly into the storage tank feeding the pump at the fuel pontoon. Water got everywhere and messed up the fuel injection system. _________________ Ancient vehicles and vessels
Gezz Samba Member
Posted: Sat Apr 20, 2024 4:19 pm Post subject: Re: surging, backfiring |
this is the filter/regulator after I replaced the internal filter element. _________________ Beachside Mechanic
69 Double Cab
73 Thing
