robin.richard Samba Member
Joined: February 17, 2012 Posts: 499 Location: V. Beach VA
Posted: Fri Apr 19, 2024 6:11 pm Post subject: New Rear Drum issues |
Hello,
Have to replace my rear driver’s side large nut brake drum. Original VW drum got scared because I didn’t check and change my rear brake pads soon enough. Measuring the drums they clearly have been turned before and will be out of spec if they are turned again.
I ordered a rear drum from a popular VW parts dealer. First impressions were the drum looked to be of high quality. Label indicated the drums were from a Danish / German company (same company that makes the exhaust sets) but there was also EMPI and Brazil on the label. So I really don’t know where they are from.
The issue is the drum doesn’t slide on the axle. The original drum is easily installed and removed but this new drum only goes on about an inch or two. I used a wire brush and solvent to clean all parts. I’ve applied a thin coat of anti-seize to both drum and axle splines. I even used a rubber mallet and could only get it about 1/4 on. At that point I needed a puller to get it back off.
The parts company is sending a replacement, so that’s good, but is this normal with new drums? I have replaced a rear drum before but don’t remember it being this hard to install. Am I missing something?
-Rich _________________ Drive your bus! |
Posted: Fri Apr 19, 2024 6:18 pm Post subject: Re: New Rear Drum issues |
Here are some photos of the drum in question:
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24806 Location: Olympia Wash Rinse & Repeat
Posted: Fri Apr 19, 2024 10:18 pm Post subject: Re: New Rear Drum issues |
robin.richard wrote: |
The parts company is sending a replacement, so that’s good, but is this normal with new drums? I have replaced a rear drum before but don’t remember it being this hard to install. Am I missing something? |
Can not say that it is normal, but has happened before. Knew one fellow that ended up having a spare axle machined for a cutting edge and then chrome plated to harden it. He used the spare stub axle as a broach with a hydraulic press. _________________ In Stereo, Where Available! |
Culito 11010101
Joined: December 07, 2006 Posts: 5867 Location: Columbia Missourah
Posted: Sat Apr 20, 2024 8:40 am Post subject: Re: New Rear Drum issues |
I have had to file the spline "landings" (grooves) in new drums. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Posted: Sat Apr 20, 2024 9:46 am Post subject: Re: New Rear Drum issues |
Culito wrote: |
I have had to file the spline "landings" (grooves) in new drums. |
That seems like a lot of work for a new drum. But I guess we got to do whatever it takes since they don’t make them like they used to. I take it you are filling the groves slightly wider, thus making the splines narrower? Long square file?
Posted: Sat Apr 20, 2024 9:55 am Post subject: Re: New Rear Drum issues |
I take it you are filling the groves slightly wider, thus making the splines narrower? Long square file? |
That would depend on how the broach was worn down or resharpened badly. Best way to figure it out is to use the eye with a magnifying glass each time you try to fit on the drum. Using something like machinist blue die or even a magic marker can make this easier by being rubbed off showing where the axle is tight.
You need to be careful not to make the fit too loose or the drum splines will fail all too soon. _________________ In Stereo, Where Available! |
Chuey Samba Member
Joined: October 18, 2010 Posts: 859 Location: Oceanside, California
Posted: Sat Apr 20, 2024 11:45 am Post subject: Re: New Rear Drum issues |
Culito wrote: |
Long square file?
-Rich |
Probably a mill bastard file would work for the grooves. A square file would be cumbersome if it worked at all. That is because it would be pretty small to fit into the grooves.
Chuey |
Posted: Sat Apr 20, 2024 12:09 pm Post subject: Re: New Rear Drum issues |
I’ll wait for the replacement to show up. Hopefully it will fit better.
Problem is I’m dead in the water until I get a drum to fit. It’s a particular bummer given the good weather and a holiday today. 😎 _________________ Drive your bus! |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 372 Location: Mississippi
Posted: Sat Apr 20, 2024 2:58 pm Post subject: Re: New Rear Drum issues |
Sometimes even with older used drums too much anti seize or grease can make for a tight fit of a drum on the splines. Sometimes you just have to rotate the drum before trying to fit it to try a different set of splines to match up. Once you find the spot that works the best you can match mark the drum snout and axle end with a paint marker before you fit the nut and cotter pin. _________________ Never argue with an Idiot. They'll only bring you down to their level and beat you with experience. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14297 Location: Casa de Oro, California
Posted: Sat Apr 20, 2024 6:23 pm Post subject: Re: New Rear Drum issues |
Is the drum on the right marked "tight" your original drum you are replacing? If so what is the diameter now? |
berpsta Samba Member
Joined: October 06, 2008 Posts: 115 Location: West Yorkshire England
Posted: Sun Apr 21, 2024 1:56 am Post subject: Re: New Rear Drum issues |
Looks like a lotta meat left on the old hubs for them to be machined and not that badly pitted or worn |
Posted: Sun Apr 21, 2024 8:22 am Post subject: Re: New Rear Drum issues |
berpsta wrote: |
Even in new drums the "meat" is a very thin area. _________________ In Stereo, Where Available! |
Posted: Sun Apr 21, 2024 10:09 am Post subject: Re: New Rear Drum issues |
New spec for rear brake drums is 9.055 with plus or minus .008".
Wear limit is 9.113".
So that means only 0.058" difference. That is less than 1/16" of an inch, and keep in mind that is in a circle of the drum. So when being lathed if the cutter is moved 0.031" (AKA 1/32") even on a new drum that cuts out all of the usable "meat of the drum and is therefore worn out.
Personally waiting for the new laser tech of today to come down in price that is being used for very expensive parts like WW2 aircraft engines to add on new material to bring them back in spec. Got a small pile of original VW drums to get that done on. _________________ In Stereo, Where Available! |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13291 Location: Tejas!
BarryL Samba Member
Posted: Sun Apr 21, 2024 6:34 pm Post subject: Re: New Rear Drum issues |
I would just sand the gloss of the old drum with 80 grit. |
Culito 11010101
Posted: Fri Apr 26, 2024 5:12 pm Post subject: Re: New Rear Drum issues |
Eric&Barb wrote: |
You need to be careful not to make the fit too loose or the drum splines will fail all too soon. |
Deeper, not wider, if I remember right. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
Ojai63dbl Samba Member
Posted: Sat Apr 27, 2024 7:34 am Post subject: Re: New Rear Drum issues |
<edited> I ran into this problem last year and seems to be a problem since at least 2018
https://www.thesamba.com/vw/forum/viewtopic.php?t=696974&highlight=new+drum+tight
I had the same issue on my new >64 drums with two different brands (Italian and Danish (?)) from two separate reputable dealer. Wolfsburg confirmed this is an issue and recommended filing.
I ended up having to file the drum spline on drum with Prussian Blue dye to make the fit (Just remember to mark drum as this will be specific to axle spline).
Unfortunately even after working on it a few days for both sides, while it was close I still had to encourage (press or rubber mallet) the drum onto axle and use a puller to remove the drum from axle.
Couldn't use the originals as I stepped up from a 63 1-Ton to a 64 tranny for the better reduction box gearing |
Posted: Sun Apr 28, 2024 6:23 am Post subject: Re: New Rear Drum issues |
Finally got the replacement brake drum. It was a replacement from the same manufacturer and it fit like a glove. I’m glad I waited a few extra days and didn’t decide to file the drum splines on the first new drum that clearly didn’t fit.
Here is a photo of the manufacturer shipping case for the replacement drums:
Here is a photo of the OG VW drum. I wish I could save it but I think it’s too far gone. I have someone that will turn it for free so I’ll probably give it a shot. Current measurements are 9 13/16” across and average 10.95mm thickness around the inside edge. Hard to get the thickness measurements with the inside ridge getting in the way. What do you think, is there enough meat to have this drum turned?
Posted: Sun Apr 28, 2024 8:04 am Post subject: Re: New Rear Drum issues |
Here is a photo of the OG VW drum. I wish I could save it but I think it’s too far gone. I have someone that will turn it for free so I’ll probably give it a shot. Current measurements are 9 13/16” across and average 10.95mm thickness around the inside edge. Hard to get the thickness measurements with the inside ridge getting in the way. What do you think, is there enough meat to have this drum turned? |
Hard to tell without 3D photos. If your friend is willing to cut it AND not strive for perfect finish, then give it a try. _________________ In Stereo, Where Available! |
Posted: Sun Apr 28, 2024 9:45 am Post subject: Re: New Rear Drum issues |
Eric&Barb,
Doesn’t hurt to try. Otherwise it would just end up in the recycling bin anyway.
I wondered if I cleaned it up with some sandpaper would it work? If I had nothing else and was in a pinch.
Both my front drums are VW and now both my rear are aftermarket. Need to find some rear VW drums locally.
