Barking Squirrel Samba Member
Joined: April 28, 2023 Posts: 64 Location: Halifax, Nova Scotia Canada
Posted: Mon Apr 22, 2024 5:33 am Post subject: Stiff, Harsh, Kidney Busting Suspension- Options |
Hey Vanagoe'rs.
Well, I can't take it anymore.
Previous owner put in lower H&R sport springs and Bilstein Shocks 19-02 that give better smooth highway handling BUT are brutal on bumps, potholes, bridge transitions etc. Dirt roads are really awful if not impossible. See photos for what is currently on the van. 1980 vanagon.
Wondering about options:
1) change to softer shocks. - within budget range.
2) change out springs. - getting expensive.
3) do both. - yup, painfully expensive.
4) others?
What would you suggest?
FYI-
Van is packed lite: only me, no propane, no roof boxes, just food and water.
_________________ 1980 Vanagon L 235k, Dual Carbs, "Mattie". Air Cooled. |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1044 Location: san diego
Posted: Mon Apr 22, 2024 5:38 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
a set of second hand stock height, or carat springs might solve most if not all of your problems. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
4Gears4Tires Samba Member
Posted: Mon Apr 22, 2024 5:56 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Agreed, get a set of used stock springs. Your shocks are fine.
I have these springs on one of my e30s, they are great in the twisties and rough whenever you hit anything. I wouldn't want them on a van. _________________ '87 Syncro
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17202 Location: Retired South Florida
Posted: Mon Apr 22, 2024 6:07 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Again I am seeing aftermarket springs in coil bind. When the coil binds, you have lost that usable part of the spring. I agree going back to stock springs would be the affordable direction. I have 40 years on my stock springs without issue. Otherwise reach out to Christopher at T3 Technique. You can get your ride back. _________________ ☮️ |
jimf909 Samba Member
Posted: Mon Apr 22, 2024 6:12 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
What tires are on the van? Dimension and air pressure? They may be contributing to the poor ride. _________________ - Jim
Abscate wrote: |
Posted: Mon Apr 22, 2024 6:23 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Looks like they have 16s or 17s with a lower than stock sidewall but not anything that will make it super rough, unless they are run flats. The spring replacement is definitely the first place to start. _________________ '87 Syncro
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1094 Location: Atlanta, GA
Posted: Mon Apr 22, 2024 6:30 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
What kind of suspension bushings are in the control arms? OEM type rubber or polyurethane? _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Joined: January 01, 2007 Posts: 16903 Location: sticksville, ct.
Posted: Mon Apr 22, 2024 7:05 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
i had the same setup on my westy
ditch the bilsteins and get a set of SPAX from T3 Technique
Bilsteins have always rode like shit and are fine for auto-x etc but not daily driver imho
the SPAX and the H&R purples made my van drive like stock without feeling like a waterbed
basically firm enough to throw it into corners and soft enough not to shake the fillings out of your teeth _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 609 Location: Lodi, CA
Posted: Mon Apr 22, 2024 8:18 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Are the stock bump stops still in place? they are probably bottomed out if lowered _________________ 83 Air-cooled 2.0 Tin Top |
Posted: Mon Apr 22, 2024 8:37 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Thanks for all the quick replies!. Samba always produces great ideas.
For some of the questions:
- not bottomed out on the rubber stops.
- 215/65 R16 yokohama Avids at 35 psi.
- No Poly Bushings.
Mark - I will crawl underneath again and see how badly the coil's are bound.
Time to order standard/stock springs.
CIP1 and Concept - the places to go in Canada - are all out of stock for at least 3 weeks.
Patience is a virtuous PITA.
Posted: Mon Apr 22, 2024 9:07 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
CIP coils are caca. _________________ 83 Air-cooled 2.0 Tin Top |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2754 Location: San Luis Obispo, CA
Posted: Mon Apr 22, 2024 9:19 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Why order new springs whene there are plenty of used springs that can work for you? if you want to go back to stock height, there are plenty out there. If you like the lower stance, get a set of carrat springs. Not quite as common in the classifieds, but also available. I'd spend the money on the shocks.
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Mon Apr 22, 2024 9:22 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Plenty of used springs in the classifieds for about $150. _________________ '87 Syncro
Posted: Mon Apr 22, 2024 9:34 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Thanks, I will look in the classifieds.
Mateo....long time since I heard the word "caca".
Posted: Mon Apr 22, 2024 10:11 am Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Barking Squirrel wrote: |
I used them and the was the nicest way i could describe CIP coils. Not that gowesty are much better. I'd go with something more OEM _________________ 83 Air-cooled 2.0 Tin Top |
Posted: Mon Apr 22, 2024 2:06 pm Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Hey Mark:
Yup, I feel like a newbie or old age selective sight.
The spring issue was sitting right in front of me. The rears and fronts are already compressed/bound just sitting on a flat road....
Can't wait for newer and proper springs...
Shucks. _________________ 1980 Vanagon L 235k, Dual Carbs, "Mattie". Air Cooled. |
Posted: Mon Apr 22, 2024 7:25 pm Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
I’m running the original 40 year old springs with yellow Bilsteins and have no complaints. Don’t sweat not catching the binding coils. I see it here all the time. I still think reaching out to Christopher at T3 Technique. He is an active member and is a wealth of suspension information. _________________ ☮️ |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6250 Location: Portland OR
Posted: Mon Apr 22, 2024 7:48 pm Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
MarkWard wrote: |
Again I am seeing aftermarket springs in coil bind. When the coil binds, you have lost that usable part of the spring. |
Again, a total misunderstanding of how dual rate springs work. _________________ 89 Westy 2.1 Auto |
E1 Samba Member
Joined: January 21, 2013 Posts: 6661 Location: Westfalia, Earth
Posted: Mon Apr 22, 2024 9:41 pm Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Unless I missed something, I took what Mark said to mean that whatever areas of the spring that are compressed to the point of touching effectively means those areas are no longer a spring at all — which is true.
I saw no reference to “dual-rate.” _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
kamzcab86 Samba Moderator
Posted: Mon Apr 22, 2024 11:22 pm Post subject: Re: Stiff, Harsh, Kidney Busting Suspension- Options |
Previous owner put in lower H&R sport springs and Bilstein Shocks 19-02 |
I put H&R Sport springs on my Cabriolet, along with Bilstein Sport shocks. Handled awesome when cornering, but on these sh***y Arizona roads, the combination was lousy. Sold the set and went back to stock.
On my Westy, I've got GoWesty's Zero-lift springs and Bilstein XHD shocks. Somewhat stiff, but not overly harsh, not soft... they work for me.
As for your setup, I agree with everyone else, ditch the H&R springs. The shocks: What is all that fluid on the front end, particularly on the upper portion of the shock? Are the shocks leaking, or is it from something else? _________________ ~Kamz
2016 Golf GTI S
