Hydro626 Samba Member
Joined: March 11, 2009 Posts: 191 Location: Atlanta, GA
Posted: Tue Apr 23, 2024 8:28 pm Post subject: Ignition switch wiring issue: make it make sense |
I've got a 72 Super that I've been driving for about 15 years now. Recently I noticed some of the wires behind the ignition switch got pretty hot sometimes. I figured out that they only get hot when the headlights are on. I have no idea how long they've been doing this.
Looking at the back of the switch I see where I rigged the system 15 years ago by tying the headlight (black/yellow) wire to the ignition (black) wire and sticking them both on terminal 15. "I should probably fix that" I thought to myself, and so I split the two wires up with new connectors and plugged them into their correct terminals: 15 for the black and X for the yellow/black.
Aaaaand the car won't start. The headlights come on with the key on but the car won't start. Confused, I tied the wires back together and the car starts right up.
What on EARTH is going on? Isn't the black/yellow wire supposed to deliver power TO the headlights? How could the ignition wire be getting power from it? Or is it getting a ground through that wire? Can I leave them tied together like they've been for over a decade now and not cause any problems? _________________ 1972 Volkswagen baja Super Beetle "Elizabeth"
1989 Cadillac Brougham D'elegance
"Never name your car...too much unhealthy emotional connection coupled with your human dark/light,yin/yang energy affects the mechanical health of the vehicle and causes magnetic convergences like the one you just had.that, or some old f**k backed into your car,its hard to tell..." -johnnypan |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12761 Location: on a bike ride somewhere
Posted: Tue Apr 23, 2024 8:58 pm Post subject: Re: Ignition switch wiring issue: make it make sense |
It sounds like the 15 portion of your switch went out, and you supplied 12v to the ignition circuit through the X (headlight/wiper) output on the switch. Since the X terminal was doing double duty, I'd replace your ignition switch now with one that hasn't been heat-warped.
www.airschooled.com |
Posted: Tue Apr 23, 2024 9:11 pm Post subject: Re: Ignition switch wiring issue: make it make sense |
airschooled wrote: |
Robbie |
Both headlights and ignition are tied together and plugged into terminal 15 when it works. You might be right about the ignition switch tho _________________ 1972 Volkswagen baja Super Beetle "Elizabeth"
ashman40 Samba Member
Joined: February 16, 2007 Posts: 16005 Location: North Florida, USA
Posted: Wed Apr 24, 2024 1:33 pm Post subject: Re: Ignition switch wiring issue: make it make sense |
Power comes into the ignition switch over the solid red #30 wire. This is battery constant 12v+.
Inside the ignition switch, the key in the ON/RUN position will power both #15 (black wire) and #X (black/yellow wire) from #30. When you turn the key to START power is cut from the #X terminal while #15 and #50 (red/black wire) which powers the starter solenoid are powered. By powering both of these wires the engine will crank and the ignition will spark the spark plugs. The #X wire which powers the wipers, headlights and blower is not powered while the starter is cranking.
Separate your merged wires and test your ignition switch wires.
#30 (red) = constant 12v+
#15 (black) = 12v while key is in ON/RUN and START
#50 (red/black) = 12v only while key is in START
#X (black/yellow) = 12v only while key is in ON/RUN position
Using the above test, confirm whether it is the #15 or #X output of your ignition switch which had failed?
If your ignition swith #15 is working and #X is not, you can continue to use your ignition switch but I would recommend adding a cheap 30A SPST relay on the #15 wire between the ignition switch and the fuse box. The output of the relay can power BOTH the #15 and #X wires. The only difference with this arrangement is your headlights and wipers will continue to work while your crank the engine. As long as you have a strong battery you are good.
Otherwise, if either #15 or #X output is not working you could replace your ignition switch with a new one. I would still suggest adding the relay on the #15 wire as a way to extend the life of your new (Chinese made) igniton switch. You should also add a Hard Start Relay on the #50 wire under the rear seat. Also to extend the life of your new ignition switch. The relays reduce the current load on the internal contacts of the ignition switch so they can last decades. Without the relays the internal contacts can burn and become unreliable after only a few months/years. _________________ AshMan40
Posted: Wed Apr 24, 2024 6:55 pm Post subject: Re: Ignition switch wiring issue: make it make sense |
ashman40 wrote: |
Otherwise, if either #15 or #X output is not working you could replace your ignition switch with a new one. I would still suggest adding the relay on the #15 wire as a way to extend the life of your new (Chinese made) igniton switch. You should also add a Hard Start Relay on the #50 wire under the rear seat. Also to extend the life of your new ignition switch. The relays reduce the current load on the internal contacts of the ignition switch so they can last decades. Without the relays the internal contacts can burn and become unreliable after only a few months/years. |
This is exactly the sort of information I was looking for! Thank you so much! I'll test the switch tomorrow.
I recently installed a starter relay as you said, and I guess a relay for the ignition wire would work in a similar manner? The current ignition circuit would work as the control power for the relay and I'd have to bring 12v in from somewhere else to actually feed the ignition? Or do I have it backwards? _________________ 1972 Volkswagen baja Super Beetle "Elizabeth"
Posted: Thu Apr 25, 2024 10:11 am Post subject: Re: Ignition switch wiring issue: make it make sense |
Just went out and tested the ignition switch with a test light. Everything checked out. 12v at every point where it should be and nowhere where it shouldn't be. I genuinely don't know why separating the black wire and the yellow/black wire made the car not start. Unless that was a bad spade connector on the black wire somehow ¯\_(ツ)_/¯ _________________ 1972 Volkswagen baja Super Beetle "Elizabeth"
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3906 Location: Seattle, WA
Posted: Thu Apr 25, 2024 11:18 am Post subject: Re: Ignition switch wiring issue: make it make sense |
So the defect in your ignition circuit must be downstream from the ignition switch. According to the stock wiring diagram, the black wire from term 15 on the ignition switch goes to the supply side of #11 fuse, which is connected internally to the supply side of #12 fuse, which is connected by black wire to the ignition coil term. #15. The headlight switch is not involved in any way in that circuit. _________________ '67 bug: seized by the authorities
Posted: Thu Apr 25, 2024 12:38 pm Post subject: Re: Ignition switch wiring issue: make it make sense |
kreemoweet wrote: |
So the defect in your ignition circuit must be downstream from the ignition switch. According to the stock wiring diagram, the black wire from term 15 on the ignition switch goes to the supply side of #11 fuse, which is connected internally to the supply side of #12 fuse, which is connected by black wire to the ignition coil term. #15. The headlight switch is not involved in any way in that circuit. |
That was it! Found the ignition wire going to the coil attached to fuse #10 with the headlights. The black wire at the ignition switch wasn't doing anything and the headlight wire was carrying both circuits. This is also why it wouldn't start when the headlight wire was on its proper terminal. All sorted! Thanks everyone! _________________ 1972 Volkswagen baja Super Beetle "Elizabeth"
Posted: Thu Apr 25, 2024 1:35 pm Post subject: Re: Ignition switch wiring issue: make it make sense |
Good job troubleshooting!
