Whaanga Samba Member
Joined: May 07, 2016 Posts: 630 Location: Rochester, NY
Posted: Wed Apr 24, 2024 10:16 am Post subject: Clutch Disc Health |
I've got the engine out of my bus for some clean up and maintenance. I am ready to starting putting things back tougher and am seeking help per which of the two clutch discs I should use. This is the one that I have been using for the past six years and it has been working well.
But there seems to be some separation in the material as seen here:
This one has some rust on the springs but otherwise appears to be in good health:
The thickness is the same for both.
OR are these two discs no good and is it time for a new one?
Thanks,
Jeff _________________ Late 1973 Bay w/a transplanted 914 Engine |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51257 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Apr 24, 2024 11:06 am Post subject: Re: Clutch Disc Health |
I'd stay away from the one with the check marks in the lining, you say the thickness' are the same, just what is that number? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Apr 24, 2024 11:33 am Post subject: Re: Clutch Disc Health |
Thanks BusDaddy,
I did some more specific measuring the one with the checking is 9mm and the other one is 10mm. _________________ Late 1973 Bay w/a transplanted 914 Engine |
Joined: August 31, 2013 Posts: 12883 Location: North Carolina
Posted: Wed Apr 24, 2024 11:57 am Post subject: Re: Clutch Disc Health |
A new disc costs less than $60. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Joined: January 01, 2007 Posts: 16910 Location: sticksville, ct.
Posted: Wed Apr 24, 2024 4:34 pm Post subject: Re: Clutch Disc Health |
TDCTDI wrote: |
A new disc costs less than $60. |
but doing the job twice is priceless _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Apr 24, 2024 7:56 pm Post subject: Re: Clutch Disc Health |
Quote: |
but doing the job twice is priceless |
I'm not trying to be a cheapskate - just seeking to learn. Thanks for the comments and advice. Am looking to source a new 210 mm clutch plate but so far have not found one for under $60. But that's not necessarily my goal. _________________ Late 1973 Bay w/a transplanted 914 Engine |
germansupplyscott Samba Member
Posted: Wed Apr 24, 2024 8:10 pm Post subject: Re: Clutch Disc Health |
TDCTDI wrote: |
Unfortunately the 210mm disc is the most expensive one out of all the Bus discs. Probably close to 3x that. _________________ SL |
Posted: Thu Apr 25, 2024 2:53 am Post subject: Re: Clutch Disc Health |
Ok, so you have the most expensive version of the available options…. Even at $185, that’s less than the tow truck is gonna cost. How much is your time worth to do it again?
And just know that a worn out clutch will inevitably fail at the worst time possible. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Apr 25, 2024 5:56 am Post subject: Re: Clutch Disc Health |
I can get you a Sachs for $125 + shipping.
Or, here’s a seller that has them for $95 shipped…
https://www.thesamba.com/vw/classifieds/detail.php?id=2267786 _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
