2002 MK4 Jetta - OBD will not "Talk" to Scanner
Forum Index -> Water-cooled VW Share: Facebook Twitter
hihorn
hihorn is offline
PostPosted: Thu Apr 25, 2024 9:50 pm    Post subject: 2002 MK4 Jetta - OBD will not "Talk" to Scanner Reply with quote
this Jetta has been all over Los Angeles to top shops trying to find out why scanners cannot retrieve codes from the car. It won't pass emissions because the testers cannot connect to the car. The scanners light up, but after a long time, scanner say's it can't connect. HELP!
82 Diesel Westy, Turbo Charged, ground up restoration.
kamzcab86
kamzcab86 is offline
PostPosted: Fri Apr 26, 2024 2:19 pm    Post subject: Re: 2002 MK4 Jetta - OBD will not "Talk" to Scanner Reply with quote
Does this car have an aftermarket radio installed?
~Kamz Anxious
2016 Golf GTI S
hihorn
hihorn is offline
PostPosted: Fri Apr 26, 2024 4:01 pm    Post subject: Re: 2002 MK4 Jetta - OBD will not "Talk" to Scanner Reply with quote
It did have a Pioneer head unit for years. The Yellow and red "K" wire has been cut, but still wont read. We are using a top of the line Snap-on Code reader and a lap top with the same results.
kpf
kpf is offline
PostPosted: Fri Apr 26, 2024 4:09 pm    Post subject: Re: 2002 MK4 Jetta - OBD will not "Talk" to Scanner Reply with quote
If the car runs and drives fine, the ECU itself is probably fine. Maybe you have to inspect and test the wiring & connectors from the OBD connector to the ECU.
1971 Super Beetle
kamzcab86
PostPosted: Fri Apr 26, 2024 7:35 pm    Post subject: Re: 2002 MK4 Jetta - OBD will not "Talk" to Scanner Reply with quote
The K-line should be gray/white and cut (and taped) at the radio-end of the harness.
If the K-line has indeed been cut, then apparently other modules in the car can be causing the issue, including the instrument cluster.
https://www.vwvortex.com/threads/k-line-hold-up.8674433/
~Kamz Anxious
2016 Golf GTI S
hihorn
hihorn is offline
PostPosted: Sat Jun 15, 2024 3:09 pm    Post subject: Re: 2002 MK4 Jetta - OBD will not "Talk" to Scanner Reply with quote
I am looking under the dash for the "pig tail" where all the "K" wires meet. Can anyone tell me where to look for this. There are several videos on line, but they are from an Audi or a VR6 Golf. They seem completely different under the dash. Or, can anyone point me to a shop in the Los Angeles area who has actually done this before?
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
