thomast Samba Member
Posted: Sun Apr 28, 2024 1:29 pm Post subject: Electrical Issues and where's the voltage regulator? |
I posted this in the "Stupid Questions" thread as well.
Is it possible to have a generator without having a voltage regulator? In our 1970 Bay Window, we're having electrical issues with the van running fine then dying and then won't start. This morning I went out and the van, which was running fine yesterday, was dead. I jump started it and it ran for about 10 minutes, then just quit. I tried jumping it again with no luck. When I turn the key when trying to jump start it, there is only a faint oil light that shows, but nothing else works and it won't turn over. Started to investigate and realize that there is no voltage regulator in the engine bay. Could it be in another location? In our bus, the positive wire (D+ post?) on the generator goes directly to the starter. When I look at Voltage Regulator diagrams, they show it going from the generator to the voltage regulator and then to the starter. I'm pretty lost when it comes to electrical stuff obviously. Any help would be appreciated. Thanks! _________________ 1986 Westy Syncro SVX
1970 Bay Window |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2768 Location: Hamble, Hampshire, UK
Posted: Sun Apr 28, 2024 2:22 pm Post subject: Re: Electrical Issues and where's the voltage regulator? |
That sounds like a non functional alternator or generator.
It is doing nothing.
The alternator may be a type with an internal regulator which has failed.
Or an alternator with an external regulator where either the alternator or the regulator has failed.
Or the regulator is missing.
Or the bulb is missing or blown or there is a bad connection to the warning bulb on the dash (VERY LIKELY the simplest fault.)
When you turn the key to ignition on withut cranking , both the oil pressure light and the alternator warning light should light.
Once the engine runs both lights should be off, if you blip the throttle .. _________________ Ancient vehicles and vessels
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51266 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Apr 29, 2024 6:25 am Post subject: Re: Electrical Issues and where's the voltage regulator? |
Thanks so much for the help! _________________ 1986 Westy Syncro SVX
1970 Bay Window |
