oldtech Samba Member
Joined: August 12, 2008 Posts: 140 Location: san fernando valley, calif
Posted: Mon May 06, 2024 6:44 pm Post subject: wrong plugs installed on single port 1600 1966 |
I have done everything I could think of with regards to overheating.
Carb jetting, correct vacuum distributor, rebuild correct carb 30 pict 1, correct tin pieces, tune up. But during the tune up I put the wrong Plugs Ngk B6hs.
The correct ones should be Ngk b5hs which are hotter. If I understand correctly the b5hs are hotter generating less engine heat. Is that correct _________________ The joy of saving money, buying a cheap part, is soon outweighed by regret, when the next catastrophic failure occurs. At that time the best parts have a certain luster that gleams regardless of price.
Current 1966 Beetle restored, passed vehicles Porsche 356 Super 90, Porsche 1987 Carrera 3.2 CAB, 1957 Oval top, 1952 Porsche 356. 1964 Beetle |
zerotofifty Samba Member
Posted: Mon May 06, 2024 8:33 pm Post subject: Re: wrong plugs installed on single port 1600 1966 |
The hoter plug is not about a hotter running engine, rather a hot plug retains its heat more than a colder plug. a cold plug rejects the heat from its tip easier, and thus runs cooler. To hot a plug can lead to preignition, and may damage the plug. To cold a plug wont stay as clean, i.e. foul easy.
https://www.denso.com/global/en/products-and-servi...heatrange/ _________________ Give peace a chance. No American war with Russia! |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24878 Location: Olympia Wash Rinse & Repeat
Posted: Tue May 07, 2024 8:36 am Post subject: Re: wrong plugs installed on single port 1600 1966 |
What RPM are you using for cruising??
Have you measured your cooling fan inside width out at the outer edge? Could be you have a 40 HP fan and need the wider 1500/1600 fan. _________________ In Stereo, Where Available! |
viiking Samba Member
Joined: May 10, 2013 Posts: 2698 Location: Sydney Australia
Posted: Tue May 07, 2024 3:16 pm Post subject: Re: wrong plugs installed on single port 1600 1966 |
How do you know you are overheating? _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2533 Location: Santa Cruz, CA
Posted: Tue May 07, 2024 3:31 pm Post subject: Re: wrong plugs installed on single port 1600 1966 |
oldtech wrote: |
I have done everything I could think of with regards to overheating. |
What's the highest oil temp you've seen and how'd you measure it? _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9911 Location: Oregon
Posted: Tue May 07, 2024 8:34 pm Post subject: Re: wrong plugs installed on single port 1600 1966 |
Check the engine compartment tar board (sound deadening) for a bulge right in front of the fan shroud intake.
I recently had to replace an engine due over heating. With the engine out. I found that the tar board restricted the cooling air to the fan shroud. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
