Max wheel size and offset '61 beetle rear
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
volksnut
volksnut is online now
PostPosted: Sat Feb 15, 2025 2:57 pm    Post subject: Max wheel size and offset '61 beetle rear Reply with quote
Found some 15 x 7 with 2" offset, from what I've read it's a no go in rear even with short axles.
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Thu Feb 20, 2025 5:44 pm    Post subject: Re: Max wheel size and offset '61 beetle rear Reply with quote
I would not say that a 15”x7” in the rear is a no go. A positive 2” offset wheel might have a clearance issue between the inside of the tire/wheel and the spring plate. The correct size wheel spacer should do the job without the tire/wheel pertruding outside the fender. I had Porsche 16”x 8” wheels with 225/45 tires on the rear of my 67 with stock fenders at one time.
71StandardReduction
71StandardReduction is offline
PostPosted: Thu Feb 20, 2025 7:41 pm    Post subject: Re: Max wheel size and offset '61 beetle rear Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=800042
Perhaps will help with your research.
YHWH NISSI
YHWH SHALOM
64 Pan Buggy
https://www.thesamba.com/vw/forum/viewtopic.php?p=10355566#10355566
Ruby Red 1966
https://www.thesamba.com/vw/forum/viewtopic.php?t=779597&highlight=
66 Baja
https://www.thesamba.com/vw/forum/viewtopic.php?t=792544&sid=1cfbb0e31e0ef24f8a1e9379e16fb18f
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
