extremebuggy Samba Member
Joined: March 13, 2009 Posts: 183 Location: Cleveland, TN
Posted: Tue May 21, 2024 6:01 am Post subject: Intake sealing ring |
This may be a crazy question, but is there any need to install the intake (copper) sealing ring on a buggy? My understanding is these are installed to prevent gases from entering the heater, but not sure if that is correct or how it would do that. So on a fiberglass buggy, is it really necessary to install the intake sealing ring? Thinking of installing just the intake gasket. |
![](/vw/forum/templates/subSilver/images/spacer.gif) |
Dale M. Samba Member
![](/vw/forum/images/avatars/1346942824e528d21d906c.jpg)
Joined: April 12, 2006 Posts: 20447 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue May 21, 2024 6:18 am Post subject: Re: Intake sealing ring |
On a single port intake head I believe the "sealing ring" is the gasket, yes you need it.... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Tue May 21, 2024 6:38 am Post subject: Re: Intake sealing ring |
It appears on my single port the sealing rings are separate and the gasket kit only has paper gaskets for the intake. Are paper gaskets normal for the intake, thought these were always metal? |
Posted: Tue May 21, 2024 9:22 am Post subject: Re: Intake sealing ring |
extremebuggy wrote: |
On a single port head it is a compressible copper coated ring..... There is no paper gasket for this connection.....
https://www.jbugs.com/product/311129707.html
The only metal gaskets were on DUAL PORT heads, and yes it's better to use paper gaskets.....
https://www.jbugs.com/product/113129717A.html
Paper...
https://www.jbugs.com/product/3251.html _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Tue May 21, 2024 12:38 pm Post subject: Re: Intake sealing ring |
Great explanation! Thanks Dale! The gasket kit came with the sealing rings, metal and paper dual head gaskets which I don’t need, and paper single port gaskets which I was unsure about. But sounds like I should not put them on. Guess I was just a little confused why they would include single port paper intake gaskets in the gasket kit if you don’t use them and only use the sealing ring. |
MrGoodtunes Samba Member
![](/vw/forum/images/avatars/178434341256d5ce0c0fe5a.jpg)
Joined: May 14, 2012 Posts: 872 Location: South Florida
Posted: Tue May 21, 2024 1:16 pm Post subject: Re: Intake sealing ring |
... paper single port gaskets which I was unsure about ... |
They're probably for something else. IDK what, but somebody here may chime in to solve that mystery. |
