82 Diesel radiator swap - Radiator Shroud
speedster
speedster is offline
PostPosted: Wed Oct 13, 2021 2:51 pm    Post subject: 82 Diesel radiator swap - Radiator Shroud Reply with quote
I know - lots of posts already on the subject. I just need some info on the radiator Shroud.
Having trouble sourcing a shroud, I know a shroud from 83 and later is what I need but it was mentioned it had to be a non-A/C version. I am assuming that is due to the size of the fan motor for mounting.
So is it true that all a/c versions are different or only the 86 and later?
If you happen to have a non- A/C version and lower radiator mounts laying around I would be interested in buying them.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Wed Oct 13, 2021 5:20 pm    Post subject: Re: 82 Diesel radiator swap - Radiator Shroud Reply with quote
The Vanagon 83-85 fan shroud are the small motor type you need.
The Vanagon 86-91 can be the small motor shroud, unless they came with factory A/C or are Syncro models.
Mark
speedster
PostPosted: Wed Oct 27, 2021 6:44 pm    Post subject: Re: 82 Diesel radiator swap - Radiator Shroud Reply with quote
The original diesel radiator had mount s that are inboard of the later mounts. The pics with screwdrivers show the original mounting hole locations. I got a Behr radiator from GoWesty. The upper channel had slots already cut into the front side of the channel right where the diesel mounts go. I took some aluminum strap material and made a couple brackets that form to the upper channel and go through the slots. I then drilled holes in the back side of the channel and bolted the new brackets to the radiator.
[img]https://www.thesamba.com/vw/gallery/p
ix/2229348.jpg[/img]
daltonhawk
daltonhawk is offline
PostPosted: Thu Jun 06, 2024 2:11 pm    Post subject: Re: 82 Diesel radiator swap - Radiator Shroud Reply with quote
So you were able to use the original 82 diesel shroud with the new radiator?
