tehillah1 Samba Member
Joined: August 23, 2009 Posts: 308 Location: Colorado
Posted: Fri Jun 14, 2024 11:41 am Post subject: Epoxy Primer over OG paint |
I'm pulling together everything I need to prime/seal up the underside of my 55 Type 1. The OG paint on many of the underside panels is solid. Whatever isn't I have taken down to metal.
I have been informed that urethane based primers will interact poorly with the OG paints of that era.
What kind of experience have folks had with laying epoxy primer over solid, original paint and blending to bare metal?[/b] |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2211 Location: Bulli Klinik, Colorado Springs
Posted: Sat Jun 15, 2024 7:22 am Post subject: Re: Epoxy Primer over OG paint |
As long as it's scuffed and cleaned appropriately, you shouldn't have any problems. The cut sheet for your primer will tell you appropriate surfaces. The only issues I've seen with epoxy is applying it over acid prepped surfaces. _________________ PM me about quality metal-work on your vehicle.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Sat Jun 15, 2024 4:29 pm Post subject: Re: Epoxy Primer over OG paint |
I got the advice from the primer folks themselves...I guess the best approach is to do a test shot over some existing panels that have paint on them and see what happens... |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2772 Location: Plattsburgh, New York
Posted: Mon Jun 24, 2024 6:54 am Post subject: Re: Epoxy Primer over OG paint |
The factory enamel is as hard as nails and chemically dead. Clean and properly scruffed, it’s a perfect surface for epoxy primer. I don’t remove it if I don’t have to. |
Posted: Mon Jun 24, 2024 10:53 am Post subject: Re: Epoxy Primer over OG paint |
orwell84 wrote: |
Thanks for the response orwell.
That's exactly what I've been thinking, given how solid the original paint is attached to the metal...it does not clean back down to bare metal easily.
So it seems that if I get it feathered out where necessary and scuffed up and then get everything clean as a whistle I should be able to get a good epoxy primer on everything.
The trunk of my car is really clean, original paint so I've got some studying and figuring out how to light scuff, clean and clear coat that area.
Jim |
