Nacho_74 Samba Member
Joined: March 22, 2018 Posts: 83 Location: Norwalk,California
Posted: Mon Jul 15, 2024 4:36 pm Post subject: DTM Epoxy Primer Color |
Does it matter what color is used? |
bruceo98 Samba Member
Posted: Mon Jul 15, 2024 4:38 pm Post subject: Re: DTM Epoxy Primer Color |
No. _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
jspbtown Samba Member
Posted: Mon Jul 15, 2024 5:09 pm Post subject: Re: DTM Epoxy Primer Color |
Is it the last thing you are applying before the base coat? |
oprn Samba Member
Joined: November 13, 2016 Posts: 14769 Location: Western Canada
Posted: Mon Jul 15, 2024 6:32 pm Post subject: Re: DTM Epoxy Primer Color |
Yes, just in the fact that when you get rock chips in the future a non contrasting color will not show up the chips as bad.
Also if you use it as a seal coat just before paint (some do) then it should be somewhat in the same color range so that it doesn't take multiple coats of topcoat to get consistent coverage. Ie; use a dark primer color for dark topcoats and a light primer color for lighter top coats. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Posted: Mon Jul 15, 2024 8:22 pm Post subject: Re: DTM Epoxy Primer Color |
jspbtown wrote: |
No. I’m taking the entire body down to bare metal and wanted to protect it from flash rusting. |
Posted: Mon Jul 15, 2024 8:24 pm Post subject: Re: DTM Epoxy Primer Color |
oprn wrote: |
Also if you use it as a seal coat just before paint (some do) then it should be somewhat in the same color range so that it doesn't take multiple coats of topcoat to get consistent coverage. Ie; use a dark primer color for dark topcoats and a light primer color for lighter top coats. |
Thanks good to know…I plan on painting my bug it’s original color of Bahama Blue |
Posted: Tue Jul 16, 2024 4:55 pm Post subject: Re: DTM Epoxy Primer Color |
If you’re going down to bare metal you’re going to be doing bodywork and be repriming it any way. When you re prime it I’d use something close to the color like said above for said reasons . There are lots of companies that sell to tint-able primers . I put epoxy primer on mine after I stripped it and had to wipe the whole car with a skim coat of filler and re primed it. As far is coverage of paint you should make sure you have enough to cover it regardless of what color underlayment color you have down first . That’s why I said no . It really doesn’t matter. You will be be putting something else over it anyway . _________________ I may not be the best, but when the top 10 get together, they all talk about me. |
Bikerndiver Samba Member
Joined: December 05, 2023 Posts: 254 Location: Mid-Atlantic
Posted: Tue Jul 16, 2024 6:24 pm Post subject: Re: DTM Epoxy Primer Color |
oprn wrote: |
Sometimes the effect you want is dictated by the shade of primer under it. I used a white high build under an orange paint. It made the orange much brighter. As a matter of fact the paint seller showed pics of the base coat sprayed over white and over a dark primer...huge difference in the final color. _________________ 1966 Manx clone (possibly a Joe Poty Enterprises) named SANDY. '70 to '73 1300 cc w/1600 DP heads, twin carbs and headers |
oprn Samba Member
Posted: Wed Jul 17, 2024 10:05 am Post subject: Re: DTM Epoxy Primer Color |
It depends so much on how transparent your topcoat is how it effects the final color.
What you want is the least coats of paint possible and still have good even color. Multiple coats leads to a thick paint finish. That will result in easily chipped paint, cracks and crazing later on. _________________ Our cars get old, we get old but driving an old VW never gets old! |
Braukuche Samba Member
Posted: Sat Aug 10, 2024 8:05 am Post subject: Re: DTM Epoxy Primer Color |
VW always used gray primer in later production cars, the only exception I’ve seen is with Saturn Yellow where they used white.
I think the only reason to worry about primer color is if you are trying to get by with fewer top coats. _________________ Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia |
