DesertG Samba Member
Posted: Sat Jul 27, 2024 8:56 am Post subject: Detailing Bottom of Pan |
Hey Guys, I have a nice original pan on my 1965 Beetle and I want to take the 50 years of road grime and mud, dirt off.
I started to clean one section with Simple Green and when I got the dirt off, found a mixture of original black paint and light surface rust.
I would love to get the surface rust off without sanding. Also, maybe make it look better. Boiled linseed oil maybe?
I want to keep the originality, so I won't be painting the pan.
Any thoughts? _________________ 1965 Beetle, 1970 1600cc DP, 12v |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11127 Location: Huntington Beach, CA
Posted: Sat Jul 27, 2024 10:23 am Post subject: Re: Detailing Bottom of Pan |
Scrap off the loose rust with a good wire brush, then Ospho, followed by primer and paint. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
74 Thing Samba Member
Posted: Sat Jul 27, 2024 12:48 pm Post subject: Re: Detailing Bottom of Pan |
thank you. I have used those coatings before but that is not what I am after. I want to keep the car honest and not cover up the pan _________________ 1965 Beetle, 1970 1600cc DP, 12v |
viiking Samba Member
Joined: May 10, 2013 Posts: 3136 Location: Sydney Australia
Posted: Sat Jul 27, 2024 3:37 pm Post subject: Re: Detailing Bottom of Pan |
Clean the pan.
Brush off surface rust with wire brush
If surface rust is heavy, use a mild acid, e.g. vinegar, ospho, citric acid to remove it
Wash with water ( or water blaster) to neutralise acid
Coat with sheep fat by brush or spray can or normal spray gun.
Sheep fat? Yes, lanolin. Look up Lanox or similar.
Lanolin is the antirust treatment of choice for many 4WD enthusiasts who regularly drive on or near the beach down in Oz. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
esde Samba Member
Joined: October 20, 2007 Posts: 6321 Location: central rust belt
