breed21 Samba Member
Posted: Thu Aug 01, 2024 8:20 pm Post subject: Need help identifying engine 1995 Type 2 Kombi |
Hey ya'll, I posted this in the "Water-cooled VW" forum and was told to direct my question here.
I purchased a VW Kombi from Florida. Trying to figure out what type of engine is in it. Is it water cooled, air cooled.
Perhaps someone can help me docode the serial number, etc?
It's a 1995 VW Bus Type 2
Here's what I can make out stamped on the engine:
IGNIÇÃO 7
SP0294684
Check out the images below
Thanks so much for the help!
Posted: Thu Aug 01, 2024 10:21 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
| Looks like a dual port Type 1 engine, which likely started out as a 1600. Your tune up specs are going to be according to your distributor and to a lesser extent to your carburetor, while what's inside isn't going to matter much unless you are planning a rebuilt, in which case you don't want to order anything until you have it opened up and can verify the build. |
Posted: Thu Aug 01, 2024 10:53 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
Thanks Wildthings! Appreciate your help
I'm from Dallas and the bus is in Jacksonville, FL.
I plan on taking 2-3 days and driving it back home (about 1k miles).
Anything I should look at addressing before hitting the road.
Oil, tires, etc?
I've never owned a VW bus and just want to give myself the best chance of success at getting home. Ha!
Thanks for the advice! |
Posted: Thu Aug 01, 2024 11:38 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
| Be prepared to rent a pickup truck and trailer in case of a break down, you don't what to have to abandon your find. |
RWK Samba Member
Posted: Fri Aug 02, 2024 5:44 am Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
Hole in rear tin will need to be covered before you start out, vital to engine cooling, make sure everything is sealed up correctly _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Posted: Fri Aug 02, 2024 7:27 am Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
Forgive my ignorance RWK, but what are you referring to you say "hole in rear tin"?
Thanks! |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2800 Location: Ocean Beach - San Diego
Posted: Fri Aug 02, 2024 7:36 am Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
| Will do, thanks! |
Posted: Fri Aug 02, 2024 2:02 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
| breed21 wrote: |
Thanks! |
The tin on an aircooled engines keeps the cool air separated from the hot air so the cooling system works its best. More pictures of you engine compartment would be good as we could tell more about what parts of your cooling tin is missing or damaged. |
my59 Samba Member
Joined: August 13, 2003 Posts: 4018 Location: connecting the dots
Posted: Fri Aug 02, 2024 6:42 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
| Wildthings wrote: |
| breed21 wrote: |
Thanks! |
The hot air is under the engine, the cool air above. You want to seal, plug gaps between the two. Big round hole in tin at lower part of first photo, for example. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Joined: August 31, 2013 Posts: 13366 Location: North Carolina
Posted: Fri Aug 02, 2024 7:25 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
I can’t say that I wouldn’t do it, because, well…
https://www.thesamba.com/vw/forum/viewtopic.php?t=792499&highlight=hey+y%92all
But the fact that you’re unable to identify whether it was water cooled, or air cooled, signals that you’re absolutely unfamiliar with a VW & this is likely to cause you lots of trouble.
How deep are your pockets? Your questions indicate a substantial lack of mechanical experience. Are you able afford the tow, and each repair should it likely break down? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Stinky123 Samba Member
Joined: January 31, 2022 Posts: 251 Location: Grand Junction, CO
Posted: Fri Aug 02, 2024 8:59 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
This is quite interesting....
What sort of trans?
A Type 1 won't fit a Type IV trans....I think, or will it? |
Posted: Sat Aug 03, 2024 6:21 am Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
| my59 wrote: |
| Wildthings wrote: |
| breed21 wrote: |
Thanks! |
The hot air is under the engine, the cool air above. You want to seal, plug gaps between the two. Big round hole in tin at lower part of first photo, for example. |
Without seeing more pictures of the engine we have no idea what else might be wrong/missing. |
favguy Samba Member
Joined: January 25, 2012 Posts: 269 Location: England
Posted: Sat Aug 03, 2024 3:08 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
| Stinky123 wrote: |
What sort of trans?
This bus is a Brazilian T1.5 Hybrid. It has a Brazilian specific modified type 1 style transmission, not a type 2 German bus trans. It still has split screen bus structure and gearbox mounting forks, nothing like a German bay.
Any pictures of the bus? |
Posted: Sat Aug 03, 2024 3:52 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
Hey everyone, thanks so much for all the support, appreciate it.
TDCTDI, you're absolutely right brother! I have no clue about engines, let along a VW Type 2, Brazilian style. So, yes there's a definite lack of mechanical experience. That being said, I'm a quick learner.
I live in Dallas, TX. To transport the bus is around $1,200, to fly and drive around $400-500. I thought I'd take a couple days, drive slow and learn as I go.
Here's a few more photos of the bus and engine:
Here's a dropbox link to the engine running (hopefully this link works):
https://www.dropbox.com/scl/fi/1lmgj5pbvvjt4eym6v3...b&dl=0
I researched the "hole in rear tin" as mentioned by RWK and understand the concept of the heater/air hoses.
My question would be: can I just cap those of with some foil tape, or should I just install the hoses and clamps myself.
I've got about 1k miles of hot weather coming across Florida, Mississippi and Texas. Should I leave it open, or just close them temporarily with foil tape?
I plan on having my mechanic (who works on old VWs) fix/tune up everything when I get home.
Thanks for the advice and wisdom ya'll.
If you need info on music theory, audio recording or computer programming, I'm your guy... haha! |
favguy Samba Member
Posted: Sat Aug 03, 2024 5:46 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
| breed21 wrote: |
Nice looking bus. You can indeed just blank off the tinware holes with something suitable and I'd recommend you do. You can't install any hoses though, as there's nowhere for them to go on your bus, it has no heating system! The 1976 to 1996 Hybrids never had heating. |
Fortitude Samba Member
Posted: Sat Aug 03, 2024 8:04 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
deleted _________________ 1971 Safare Camper
Posted: Sat Aug 03, 2024 8:14 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
Favguy, here comes another newbie question...
No heating as in, no heating in the air vents/defrost, or something to do with the engine itself.
I live in Texas, hot and cold weather.
If you could elaborate on this type of engine (hybrid), that would be cool for me to learn.
Thanks so much |
Posted: Sat Aug 03, 2024 9:22 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
What year is on the title? or the VIN plate? If it is less than 20(?) years old you may have problems getting it properly registered. You should try and get copies of any import paper work from the seller.
Hybrid refers to the body style and has nothing to do with the engine. Engine wise I don't see outlets on the fan shroud for the heater ducting, so no worry there, but you do need to close off the 2-1/2" diameter hole(s) in the rear cooling tin. Some pieces cut from the lids of a large diameter tin can will do, fastened with a few sheet metal screws and sealed with a bead of high temperature silicone. |
Posted: Sat Aug 03, 2024 9:33 pm Post subject: Re: Need help identifying engine 1995 Type 2 Kombi |
It's says 1995 on the Florida Title. No import papers.
VIN #9BWZZZ231SP033878
Wildthings, with what your talking about (fan Shroud for the heater) effect the interior heating/vents, or are you just referring to the heat flow of the engine itself (I'm assuming). Prob a dumb question, but IDK ha!
Thanks again |
