bnam Samba Member
Joined: July 02, 2006 Posts: 3557 Location: El Dorado Hills CA/ Bangalore, India
Posted: Mon Aug 26, 2024 1:30 am Post subject: Primer color |
I’m going to repaint my 65 KG the original L560 Manila Yellow. I’ve got two conflicting inputs on the color of the primer I should use. One paint guy said use white. Another said that gray or black would make the color come out more in its proper tone than white.
Any advice on which path I should follow?
Thanks
Byas _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
RLFD213 Samba Member
Posted: Mon Aug 26, 2024 5:25 am Post subject: Re: Primer color |
| Primer color shouldn’t matter. It’s the sealer you use just under the paint. Yellow takes a lot more paint than other paints do, so I’ve been told. And yes what the painter told you about light and dark is correct. |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11514 Location: Huntington Beach, CA
Posted: Mon Aug 26, 2024 8:18 am Post subject: Re: Primer color |
Get the white tinted yellow. They can only add a tiny amount to the base, but it makes for an easier paint job. When I sprayed my yellow 70, 7 years ago, it took about 6 coats, to get the depth of color correct. That was on gray primer. Had I tinted some white, it might have been 4, maybe 5! _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
67ctbug Samba Member
Posted: Tue Aug 27, 2024 6:23 pm Post subject: Re: Primer color |
BASF has a recommended grey shade for the undercoat color. Yellow is going to cover poorly, so you'll want to use whatever the paint manufacturer recommends. The Ruby car I just did is different colors even with 5 coats depending on which undercoat I used. For L560, Glasurit recommends a very light grey sealer/primer, L06. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
| KentPS wrote: |
...or the PO envied the terrorists' bus in "Back to the Future".  |
| mukluk wrote: |
| He's fine, just waiting for the dragon in winklepickers to move out of his lane. |
shanered Samba Member
Posted: Sun Feb 16, 2025 11:10 am Post subject: Re: Primer color |
| Everyone will tell you something different. Painter has last say, lol you painter no? I use brown under yella, yellow sometimes vw used gray i think All pigments different can o worms |
2type2 Samba Member
Joined: June 02, 2002 Posts: 1229 Location: SW Colorado
Posted: Sat Feb 22, 2025 8:30 am Post subject: Re: Primer color |
I have painted both a 78 and 66 westy in Daytona Yellow. The first was painted with a Grey bond- seal primer- one gallon of yellow did not cover the darker grey primer well. Second was primed in white and 1 gallon did complete coverage on the wholebus.So go with white or yellow-tinted primer for sure _________________ "A life of peace and happiness depends on your own gratefulness" |
