Help or shop recommendations 2014 Jetta TDI DPF light
Forum Index -> Water-cooled VW Share: Facebook Twitter
55ragtop
55ragtop is offline
PostPosted: Sat Sep 07, 2024 6:44 pm    Post subject: Help or shop recommendations 2014 Jetta TDI DPF light Reply with quote
Hello all,
Having difficulties with a 2014 Jetta TDI. DPF has been replaced and the DPF dash light is still going on after reset with VCDS every 12 miles. Do you have any tips or shop recommendations in Southern California?
Thanks in advance!
borninabus
Samba R&D Dept.
borninabus is offline
PostPosted: Wed Sep 18, 2024 5:49 pm    Post subject: Re: Help or shop recommendations 2014 Jetta TDI DPF light Reply with quote
do you have VCDS?
88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
55ragtop
55ragtop is offline
PostPosted: Wed Sep 18, 2024 10:13 pm    Post subject: Re: Help or shop recommendations 2014 Jetta TDI DPF light Reply with quote
borninabus wrote:
do you have VCDS?
Yes, I do have VCDS and I've used it to reset the DPF light, but nothing further.
2002sportside
2002sportside is offline
PostPosted: Sat Oct 26, 2024 4:34 pm    Post subject: Re: Help or shop recommendations 2014 Jetta TDI DPF light Reply with quote
I know, old post...
Was the DPF reset and differential pressure sensor relearned through the VCDS after the DPF was replaced? The values need to be reset in order to read properly.
1973 Volkswagen Beetle never ending project
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
