onwardtothestars Samba Member
Joined: April 04, 2007 Posts: 385 Location: Hazenville Pass Wyoming
Posted: Thu Oct 10, 2024 4:16 am Post subject: 914 clutch alternatives |
On a stock 914 with 215mm flywheel and 901/914 transaxle is the only route for a clutch and pressure plate the factory or aftermarket 'race' parts? Perhaps is there a pressure plate and clutch disc that will work from another vw/audi/porsche ?
Thanks. _________________ Beetle, Ghia, Vanagon Syncro, and more |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80667 Location: Sneaking up behind you
Posted: Thu Oct 10, 2024 4:28 am Post subject: Re: 914 clutch alternatives |
Stock engine? Why need more than the stock clutch?
The 914 engine is similar, if not the same, as the VW Bus engines. Look at VW vendors. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Thu Oct 10, 2024 5:48 am Post subject: Re: 914 clutch alternatives |
| Glenn wrote: |
The 914 engine is similar, if not the same, as the VW Bus engines. Look at VW vendors. |
The stock clutch/pressure plate for the 914 is the same as the early 901 equipped 911's. So the price is high comparing it to about anything else for a basic stock clutch kit, because 911.
I'm prepared to buy it. I just want to know if there's alternatives. Nothing I've found as is listed as compatible, but off label I assumed there was something. Like I remember a ford ranger clutch could be used in a audi etc. _________________ Beetle, Ghia, Vanagon Syncro, and more |
Nacho_74 Samba Member
Joined: March 22, 2018 Posts: 86 Location: Norwalk,California
Posted: Thu Oct 10, 2024 7:33 am Post subject: Re: 914 clutch alternatives |
| I run a SACHS stock clutch & pressure plate in my 2270. More than enough grip and has great drivability. I picked up new from AutohausAZ for $300 |
Joined: December 28, 2016 Posts: 311 Location: atlanta ga
Posted: Tue Oct 15, 2024 7:45 am Post subject: Re: 914 clutch alternatives |
| onwardtothestars wrote: |
Thanks. |
best and easiest and cheapest just to install the stock stuff |
