1974 Ghia Accelerator cable and tube orientation
Balmoral1958
Balmoral1958 is offline
PostPosted: Sun Oct 13, 2024 5:54 pm    Post subject: 1974 Ghia Accelerator cable and tube orientation Reply with quote
This has been a problem since I owned this car. The accelerator tube pushes out into the engine bay - Per the picture there is a clamp there but doesn't seem to do anything. What is the correct connection. I have the flexible tube - - is this supposed to go over the hard tube that runs through the fan shroud? Is there a better solution available. What parts do I need? I hope this can be fixed with the engine in.
Thanks
2x 1974 Karmann Ghia Coup
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
onwardtothestars Premium Member
onwardtothestars is offline
PostPosted: Mon Oct 14, 2024 2:48 am    Post subject: Re: 1974 Ghia Accelerator cable and tube orientation Reply with quote
The tube that runs through the shroud should be flared at the carburetor end so it doesn't pull through the shroud. I've seen and experienced the flared end eventually wallow/pull through the hole in the shroud. An easy fix is to remove the tube and find a washer you can slide up the tube to the flared end and then re-install. On the back side of the engine you can put one hose clamp on the tube snuggly up against the rear tin, keeping the tube from moving back and forth. The bowden part of your accelerator cable should just fit over the end of the tube, there's nothing securing it.
Beetle, Ghia, Vanagon Syncro, and more
Balmoral1958
PostPosted: Mon Oct 14, 2024 6:52 am    Post subject: Re: 1974 Ghia Accelerator cable and tube orientation Reply with quote
Thanks
I have done most of the jobs in a Ghia. I managed to loosen the little clip in the hard tube and slide it up. Apparently this is a trick to stop the tube from sliding out at the engine side. I then managed to slide the rubber tube (has Aden as Ke end ) over the hard tube and it seems to be good. Thankfully I have a hoist. I may still order a new flexible tube.
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
PostPosted: Mon Oct 14, 2024 7:48 am    Post subject: Re: 1974 Ghia Accelerator cable and tube orientation Reply with quote
Balmoral1958 wrote:
Thanks
In 30 years of wrenching on aircooled VWs I've only seen one of the accelerator bowden tubes, and that's on the ghia I currently own.
Balmoral1958
PostPosted: Mon Oct 14, 2024 8:26 am    Post subject: Re: 1974 Ghia Accelerator cable and tube orientation Reply with quote
yes - i guess it protects the cable from dirt etc. not the smoothest system though - but it works... but not easy to replace .
1984 Citroen 2CV
1956 Citroen 2CV
!984 911 Targa
