Hot Rod Harp Samba Member
Joined: March 02, 2008 Posts: 197 Location: Englewood, New Jersey
Posted: Tue Oct 15, 2024 11:06 am Post subject: distributor rotor resistance |
Hello,
I have been unable to locate an answer to my question.
I have searched The Samba and Rob and Dave's site.
What is the resistance for the rotor on a DVDA distributor and
What is the resistance for the rotor on a Pertronics distributor? _________________ 74 Thing 1600DP
76 Westfalia 2.0L FI
69 Beetle 1500SP sold
88 Goldwing GL1500/6 sold
RinTinTin in Waldorf Astoria 1956 |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7578 Location: Houston, Texas
Posted: Tue Oct 15, 2024 11:28 am Post subject: Re: distributor rotor resistance |
The short answer is it depends. If you have a multimeter you can test it yourself. Some people use rotors with resistance and others have zero resistance.
What do you need this information for? _________________ www.vwnos.com [email protected]
Posted: Tue Oct 15, 2024 12:12 pm Post subject: Re: distributor rotor resistance |
Thanks for your reply, I do have a meter and was troubleshooting an idling issue.
I have several rotors; 2 ohms, 1k ohms, 4.95k ohms. The cap and original rotor
looked a little dark in the center. I replaced with the cap and rotor from a new
unused Pertronics distributor. My original distributor is a DVDA on a stock 1600.
I will order replacements. I read somewhere that water cooled VW rotor
resistance is 1k ohms. You rebuild distributors, are air cooled rotors resistance~5k ohms? _________________ 74 Thing 1600DP
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36387 Location: Conejo Valley, CA
Posted: Tue Oct 15, 2024 12:19 pm Post subject: Re: distributor rotor resistance |
Most stock distributors had a 5K-ohm resister cast into them.
I've seen one burn out and arc, and cause poor high speed running.
I don't know what the Pertronix units like. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
heimlich  VWNOS.com
Posted: Tue Oct 15, 2024 12:23 pm Post subject: Re: distributor rotor resistance |
The resistance can be all over the place. It depends on the manufacturer and part number. _________________ www.vwnos.com [email protected]
Posted: Fri Oct 25, 2024 9:52 pm Post subject: Re: distributor rotor resistance |
I am not sure exactly what is available, but replacing the resistance rotor with a none resistance rotor and then using a resistance coil wire would be one way to go.
heimlich will surely know more about what is available than I. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13629 Location: West Coast, USA
Posted: Tue Nov 05, 2024 8:46 pm Post subject: Re: distributor rotor resistance |
Typically, a type 1 engine with points gets the 5kohm rotor. (Most work out to about 4.9k anyway…) They typically have a narrower metal tip than the 1k ohm rotors I see on the Vanagon and 79 CA bay with electronic ignition and special coil.
I’ve never tried a zero ohm rotor, and I wouldn’t bother with a radio. Most ignition system resistance is to stop buzzing and other electronic interference, like a skittish tachometer. If your spark plug wires and/or coil wires have over 1k of resistance, it shouldn’t matter what rotor you use. If you’re using spark plug wires with no resistance, go for the 5k rotor. I’ve always felt the DVDA’s wider timing map appreciates the wider rotor tip, but that’s just speculation.
Some spark plugs have resistance built in as well. (NGK plugs have R’s at the end of their part numbers, for example.) The point is, you want SOME resistance, but not every part of your ignition system needs to be high resistance.
Pertronix manuals will list their respective resistance expectations.
Robbie _________________ WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
https://www.patreon.com/airschooled |
