IAC valve cleaning - '90 Westy, 2.1L
RBEmerson
RBEmerson is offline
PostPosted: Fri Oct 25, 2024 7:49 am    Post subject: IAC valve cleaning - '90 Westy, 2.1L Reply with quote
As part of an overall effort bring our GW-EFI in spec, I want to clean the IAC valve. AFAIK, sloshing around carb cleaner or brake cleaner, and blowing everything out afterwards should get the job done. Or...?
Lord, give me coffee to change the things I can change, and wine to accept the things I can't change.
jlrftype7
jlrftype7 is offline
PostPosted: Fri Oct 25, 2024 11:18 am    Post subject: Re: IAC valve cleaning - '90 Westy, 2.1L Reply with quote
I'm always nervous using Carb cleaner around electronic parts. I tend to start with Contact Cleaner, and move to Brake Cleaner if needed. Could be I have nothing to worry about, but, am remembering Carb Cleaner from days of old and the new stuff isn't the same. Think Think
Plastic damage is another thought.
‘84 Tin Top - Hilga....Auto
Wildthings
Wildthings is offline
PostPosted: Fri Oct 25, 2024 12:05 pm    Post subject: Re: IAC valve cleaning - '90 Westy, 2.1L Reply with quote
I tend to use WD40 as a cleaner and then lubricate with synthetic oil.
do.dah
do.dah is offline
PostPosted: Fri Oct 25, 2024 9:10 pm    Post subject: Re: IAC valve cleaning - '90 Westy, 2.1L Reply with quote
I like hooking it up to a 12v power supply and activating it while spraying my preferred cleaner, then using an airhose, blowing it out.
