Judson... Vacuum advance or not?
KennyC
KennyC is offline
PostPosted: Mon Nov 04, 2024 12:31 pm    Post subject: Judson... Vacuum advance or not? Reply with quote
Hello Team,
Quick question as per the heading -
Use of the vacuum advance with Judson Superchargers?
My Zwitter has a stock 25hp motor, but is running a later 28pci carb and matching VJU 4 BR 8 distributor with the vacuum advance fitted.
I read somewhere many years ago about disconnecting the vacuum advance as when connected there is too much advance to suit the now increased cylinder fuel/air charge, and note the sales advert photo for Judson from back in the day shows the vacuum line removed....
Does anyone have any experience running their Judson'd car on modern fuels they'd like to share before I start the installation of this Judson...??
Kindest Regards,
Ken.
vwhelmot
vwhelmot is offline
PostPosted: Thu Nov 07, 2024 9:04 am    Post subject: Re: Judson... Vacuum advance or not? Reply with quote
Cant see the oil line connected either :D Never heard of that one before. Run the vac line or better still buy an 010.
John Moxon Premium Member
John Moxon is offline
PostPosted: Fri Nov 08, 2024 4:09 am    Post subject: Re: Judson... Vacuum advance or not? Reply with quote
KennyC wrote:
As "vwhelmot" says the Vacuum line and Oiler lines are omitted from the picture. It's simply a clean illustration of the Supercharger and Throttle linkage.
John.
KennyC
KennyC is offline
PostPosted: Tue Nov 12, 2024 5:07 pm    Post subject: Re: Judson... Vacuum advance or not? Reply with quote
Many many thanks VWhelmot and John,
I have just received a copy of the original Judson fitting instructions very kindly supplied by George Folchi which contains the wording "Refit the vacuum line by bending it to suit" which therefore answers the question.
I have the car booked for a dyno run next week before I fit the Judson. The laugh was that the company had to check the dyno would read as low as 25hp!!!
A bit of fun if nothing else!
Kindest Regards,
Ken.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Nov 12, 2024 5:23 pm    Post subject: Re: Judson... Vacuum advance or not? Reply with quote
I've seen Judson engines match to VJU4BR8/VJ4BR8/VJ4BR25/019/010 and even a 40hp Big Cap.
The VJ4BR25/010 are the most used.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
The Distributor Distributor
tasb is offline
PostPosted: Tue Nov 12, 2024 7:41 pm    Post subject: Re: Judson... Vacuum advance or not? Reply with quote
The mechanical weights advance on a VJU 4 BR 8 are identical to the VJ 4 BR 8 mechanical distributor which is identical to an "019" distributor. So essentially running a 36 hp Beetle distributor without the vacuum advance connected is the same as running an 019.
If you are going for the total correct vintage look you will want the older badge not an 019 since they didn't appear with that badge until the mid 1960's.
Roads Scholar
Member# 2059
