Sandrailnutz Samba Member
Posted: Sun Nov 24, 2024 9:18 am Post subject: Clutch pedal for autostick? |
Hey guys, new to the list here. A buddy and I acquired a VW rail buggy with a 70 motor, according to the B1 code under the generator stand. It is basicly a rolling chassis that was never finished, or hardly started. It has a frame, front/rear suspension, tires, autostick trans, engine and steering wheel. That's about it.
I already had the engine running and tested the trans, which seems fine. However, the shift control valve and vac reservoir are missing. I am wondering why i haven't read about anyone putting in standard pedals, then rigging a clutch cable to the servo somehow. I mean, i've been looking around for a control valve and they're as rare as hen's teeth and as pricey as gold. So, i'm figuring if i rig up a manual clutch until i find one at a reasonable cost, it should work just fine. Any thoughts? And, even though it also came with a spare 4 speed, i have no desire to swap. I'm on the autostick rules side, even if i only did drive one once about 30 years ago. We're not looking for gobs of power or pickup, this is just a toy to tool around in and take to shows.
We also would like a lead on a way to obtain a bunch of parts on the cheap, although the classifieds here seem pretty reasonable. We're near Hudson, Florida. Thanks in advance, and for having such a great site.
T _________________ Parts needed- Autostick control valve, vacuum can, shifter, linkage and rod, Standard pedal set with linkage, Master cylinder with top and rod, all 4 rubber brake lines, complete or semi complete wiring harness, (engine/lighting), hand brake handle (complete) with cables, Autostick speedo, steering column minus wheel (too big)- |
volkenstein Samba Member
Joined: June 26, 2005 Posts: 871 Location: The Land of Oz
Posted: Sun Nov 24, 2024 5:40 pm Post subject: Re: Clutch pedal for autostick? |
Sandrailnutz,
Go the opposite way and stick in a manual trans. Financially better off in the long run and your toy will not have to rely on the 180mm clutch plate.If you have a native & unmolested B1 prefixed Autostick motor, it was the pick of the litter. 26mm, large gallery FLAT cam oil pump. Jury-rigging a cable for an A-S clutch would be a major PITA compared to the almost Plug-n-play of manualising it.
HTH
Volkenstein _________________ 71 RHD AS Super - "Klaus"...
Wisdom of youth, energy of old age... |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2580 Location: formerly NY currently NC
Posted: Sat Nov 30, 2024 12:51 pm Post subject: Re: Clutch pedal for autostick? |
depending on the year of the chassis you may not have the guide tube that the clutch cable runs through in the first place...earlier cars didnt have them, later ones did...on a rail buggy aftermarket pedals and a hydraulic master and slave may be easier if not cheaper |
