Carb Problems
jtb_29
jtb_29 is offline
PostPosted: Fri Aug 11, 2006 1:08 pm    Post subject: Carb Problems Reply with quote
I just bought a new empi 34 pict carb for my 1641 DP. I cannot get it to tune right. Everytime I think it might be good when I go drive it, it starts sputtering and almost sounds like its backfiring through the carb. I just set the timing so that shouldnt be a problem. I would appreciate any help. Thanks
oc63rag
oc63rag is offline
PostPosted: Sat Aug 12, 2006 6:01 am    Post subject: Reply with quote
Here's a link that explains everything to check:
http://www.vw-resource.com/34pict3.html
Don't skip anything or assume it's already been done properly. It's basic maintenance and it doesn't take long to do.
Designed for four soldiers and a machine gun...also for family use.
My food baby is crowning.
napgonz
napgonz is offline
PostPosted: Fri Nov 29, 2024 11:07 am    Post subject: Re: Carb Problems Reply with quote
I’m so thankful for the samba.com
Just found out that this is the issue I have for my 64 sedan. The link is gold. I also found this procedure on YouTube in Spanish with some extra tips Very Happy Very Happy
https://youtu.be/OK0gc9YUKJk?si=S72MfuNiSoJFVCGJ
