Does anyone have experience with Eastwood Rust Encapsulator?
Low Coolant
Low Coolant is offline
PostPosted: Sun Dec 15, 2024 9:51 am    Post subject: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
Just finishing up the floors on my Beetle and want to protect them. Did some Google searching and Eastwood came up as highly recommended. Anyone have any experience with it or any other recommendations to protect new floors? Thank you all.
https://www.eastwood.com/eastwood-rust-encapsulato...e&wv=4
lqqkatjon
lqqkatjon is offline
PostPosted: Mon Dec 16, 2024 7:44 am    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
I cannot directly answer your question... but I just went through the whole rust protection coating of my Pan recently.
1. there are different products from manufactures. things to watch out for are the top coating needs. the product you mention above needs top coating for good UV protection. So does por15.
2. Eastwood has a few products similary labeled. rust encapsulator, rust encapsulator plus, and rust encapsulator platinum. they are all very differnet products when you read the fine print.
I bought rust encapsulator- it did not need a top coat. but I never used it... I still have the can.
What I found in research, is the silver products seem to have best reviews.
Por15 is hit or miss on who loves or hates it.
to SUMMERIZE:
I used Por15 silver, 2nd coated it with por15 black. and then top coated that with por15 top coat on the pans.
I used masterseries silver in the fenders, and top coated that with the masterseries black AG111
the masterseries seemed to be 1000% better product. I would for sure use that again.
the por15 silver was runny as heck and got everywhere. also did not seem to coat well and it took brushing and care to get it into the nooks and crevises. and it ran and dripped. the por15 topcoat I am not sure it is that strong.... I think I might as well just use rustoleum as a top coat.
the masterseries went on with a foam brush really nice. you could paint up next to things and it would not run down on them, or drip on everything. the ag111 went just as easily. I used that also on my rocker panel, and trying to sand the masterseries, it was super hardened.
I am sure the eastwood stuff is similar, but just be aware of the different between what needs topcoating and what does not. and the prep to top coat.
it looks like masterseries recently is harder to get ahold of... but someone just posted that they did get their order. someone also posted another alternative.
I personally will not buy por15 again. there are better products. but then again mine is now just a few months old on the paint. will see how it lasts in the future.
viiking
viiking is offline
PostPosted: Mon Dec 16, 2024 3:39 pm    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
Have a look at my hand pans painted with KBS. A couple of posts down.
https://www.thesamba.com/vw/forum/viewtopic.php?t=798384
The answer depends on whether you have new or "old" pans. For brand new pans I would just epoxy them and then topcoat them with something. Epoxy is i
incredibly hard.
The science is pretty clear. For rust to start you need water and oxygen. Any paint that "encapsulates" that and seals the steel from either water OR oxygen will stop the rusting process.
Most of these products are moisture cured polyurethanes. Raptor coating is a polyurethane.
They seal well and dry rock hard. If you follow the directions they generally work BUT most will adhere better when the metal has got a bit rusty and you use their proprietary acid (usually an acid like phosphoric or oxalic acid (wood bleach)) wash to change the iron oxide (rust) to iron phosphate. The phosphate coating provides an excellent base for the subsequent paint to stick to. In fact they suggest that you let the bare metal to in fact rust a bit then react with the acid solution rather than use the paint on new clean steel.
But like any coating if they crack or break then the rusting process can restart so inspection still has to take place. Of course some products will contain some other ingredients which may provide some residual short term sacrificial protection.
I've use KBS and Bill Hirsch Miracle Paint with great success. POR 15 I've heard is an issue on new steel, but have not directly used the Eastwood product. But I don't think it is any better or worse than the ones mentioned based on the formulae they provide on their SDS.
50 years ago and before I knew of the existence of these products I used to treat every car that I bought with my own rust proofing mixture as cars of the 70's were very poorly sealed against the weather.
The steel floors or doors were painted first with a galvanising paint, then I used a hard drying bitumen paint over the top, followed finally by a two pack clear coating used for timber floors (Estapol 7008). Whilst the smell was bad for a while, the hard coating was superb at keeping the rust at bay. And what was the Estapol made from? Polyurethane!
David Raistrick
David Raistrick is offline
PostPosted: Sun Dec 22, 2024 8:34 pm    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
yes, I've used eastwood rust encapsulator a fair amount.
I cannot recommend the silver - it's crap. it's gummy no matter what. (when it's absolutely fresh and new it's not as horrible, but give it some time...)
the black has it's place - but this is NOT like POR15. it does not form a hard shell like POR does.
when used straight out of the can, it's likely to get gummy too.
the only use I've found that I _like_ it is when working on pitted rusty panels that I can't/wont blast or replace - I thin it heavily (whatever the can says. acetone probably, it's been years), then foam brush it around the the pitted areas, then sand/scotchbright off. a few coats (it's really thin). then epoxy primer over it after it's fully cured out. mind you, I last did that in.....'08? '10? something. kirker epoxy and no topcoat, and zero issues in florida in all that time.
I have used it on rusty metal - scuff and cover. dont like it. its easier to remove than POR though, so if you are looking for a temp cover... but honestly any rattle can works just as well.
I have used it straight (black and silver) on clean metal. dont like it. I used the silver straight brushed inside my deck lid hinge panel. it's doing fine, but I haven't stuck a camera in there or anything. and my engine compartment has spent most of the time since reassembly coated in oil.
I've thinned it and shot it. don't like it.
maybe I'l stick a camera in there (since I have one now)
when I strip and redo my pitted roof again - I'll probably just use z-chrome (because I have some from when you could still get it) and wont use the RE.
...david - '66 SO-44 #231
David Raistrick
PostPosted: Sun Dec 22, 2024 8:35 pm    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
eastwood rust encapsulator is NOT moisture cured, it does not call into that category.
viiking
viiking is offline
PostPosted: Fri Dec 27, 2024 2:49 pm    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
I said MOST.
Eastwood's product is basically carbon black dissolved in a whole bunch of solvents leaving the carbon black to aid in the anti-corrosive process. It's effectiveness depends on what other chemicals are added to the paint.
Airheated
Airheated is offline
PostPosted: Fri May 30, 2025 6:18 am    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
I have used Eastwood's Rust Encapsulator on a variety of car projects. My only complaint is that I didn't discover it sooner. I was a long-time POR-15 user/sufferer, which if you wanna compare the two, Eastwood's product is like a much more user friendly version where it's half the butt pain of POR-15 to get an equally nice result. I like to cut it down a little bit with Xylene so it's a little thinner.
I live in the rust belt so anything I paint gets battle tested pretty well. Pro tip: buy a big box of throw-away cheap foam paint brushes on Amazon for application!
Ghia Dan
Ghia Dan is offline
PostPosted: Sat Sep 13, 2025 3:48 pm    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
I'm thinking about using Eastwood Rust Encapsulator on the '72 Ghia I just picked up. I'd like to use it on the undercarriage and inside the wheel wells.
My question is, would this decrease the value of an (otherwise) all-original car? I would think that, if anything, it would increase the value, but I thought I'd see what other and more knowledgeable people think!
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sun Sep 14, 2025 4:51 am    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
If you are really trying to keep the car as original as possible and the wheel wells are not badly rusted I think you would want to prime and repaint them in body color as they came from the factory for protection. But technically they are now not "original".
Ghia Dan
Ghia Dan is offline
PostPosted: Sun Sep 14, 2025 7:45 pm    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
Thanks. I'll take a closer look this winter (when I start pulling the wheels off and getting underneath), but it might be good enough to leave as-is. I was thinking of rust encapsulating as a protective measure for the future, and not really a way of dealing with any problem.
Airheated
PostPosted: Fri Sep 19, 2025 6:43 am    Post subject: Re: Does anyone have experience with Eastwood Rust Encapsulator? Reply with quote
I feel that a rust encapsulator isn't the best solution for your needs. If your wheel wells are in good shape and you're just looking for protection from the elements, a spray wax like 3M makes might check all the boxes. Not permanent but still protects original paint. A second option would be one of the lanolin based oils like Fluid Film. These types stay wet/dont harden up like a wx, but the benefit is that it creeps into small areas really well.
For my purposes (full nut and bolt restoration with the goal of tasteful OEM look but not a concourse car) I used Upol's corrosion proofing epoxy from the Raptor line, then topcoated with Raptor bedliner. Everything underneath the car, the wheel wells and trunk area was coated. Cheaper bedliners like Herculiner would work and could be roll-on applied to the well wheels, but my logic is either apply something easily removable (spray wax) or a permanent solution (2k paint/coating).
1971 Karmann Ghia Coupe
