raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23008 Location: Oklahoma City
Posted: Wed Dec 18, 2024 3:54 pm Post subject: Re: re fitting engine. |
Ok....so you have the enine out and the transmission is still in right?
Really the best way to do this is as a complete unit bolted together. But if you already have it seperated out, yes, you can tilt the trans downward and the engine upward.
Once you have the four bolst in, then do the three torque converter bolts.
But....the best way to do this:
So....
1. DO NOT remove the ears from the transmission (part #15). Too hard to et back on and tighten down.
2. DO NOT pull out bolt #20 that goes through the rubber bushing #17 on each side
3. Instead.....remove bolt #30 from each side of the beam above (part #25).
You may also need to remove the cross bolts part #26 on each (its been I while I cannot remember for sure).
The reason for this is because if you remove the bolts that go through the center of each rubber bushing...leaving the bushings attached to the rail/beam #25 above....and then try to lift the transmission and engine combination up at one time and get those rubber bushinsg back into the slots on the "ears"....the angle makes it very hard to get the rubber into the slots in theears. You end up prying and pushing because the transmission/engine package wants to slide rearward.
This is a lot of work and tears the rubber bushings up.
Its easier to lower the tranmission with the upper beam #25 still attached....join the engine and torque converter....lift the jack up and use a pointed bar to align the holes in the end of beam #25.
Ray |
