Lack of Centering on Steering
Ozmello
Ozmello is offline
PostPosted: Fri Dec 27, 2024 7:06 pm    Post subject: Lack of Centering on Steering Reply with quote
The steering on my Safari has always been very good. This morning I was driving it and suddenly there was an extreme lack of centering. I could move the steering wheel 4-6 inches without encountering any tension from the steering linkage. I pulled over and examined the front end to make sure everything was still connected. Visually, I saw no problems.
I went home, lifted the car and removed the front tires and wheels. The steering column looked good, and when I manipulated the column back and forth there appeared to be no slack there, but rather the slack appeared to be in the steering gear box. I pulled the fill plugs on the box and added 90 weight gear oil. I also adjusted the set screw on the box. The slack in the steering was not reduced.
Can the forum gurus point me in a good direction for correcting this issue?
obus Premium Member
obus is offline
PostPosted: Sat Dec 28, 2024 2:00 pm    Post subject: Re: Lack of Centering on Steering Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=665412&highlight=steering
Maybe?
Ozmello
Ozmello is offline
PostPosted: Sun Dec 29, 2024 1:49 pm    Post subject: Re: Lack of Centering on Steering Reply with quote
I've not tried adjusting the nut on the end of the steering box as I didn't have the special tool, but I will see if I can tackle it using Mondshine's hack. I also need to confirm that nothing between the steering wheel and the steering box is loose.
Ozmello
Ozmello is offline
PostPosted: Thu Jan 23, 2025 11:50 am    Post subject: Re: Lack of Centering on Steering Reply with quote
Decided to just suck it up and replace the steering box. Also replaced the tie rods and steering damper. Haven't taken it off the jackstands yet, but will likely do that tomorrow. We'll see how the camber and caster look then.
madster
madster is offline
PostPosted: Thu Feb 06, 2025 4:38 pm    Post subject: Re: Lack of Centering on Steering Reply with quote
Popcorn
1966 BEETLE @ 1973 THING
Ozmello
Ozmello is offline
PostPosted: Mon Feb 10, 2025 1:52 pm    Post subject: Re: Lack of Centering on Steering Reply with quote
LOL! Got the car off the jackstands. Front end feels good. Lack of centering and vague steering is corrected. Changed out brake shoes and found that I couldn't get the brakes to bleed, so back on jackstands and in goes a new master cylinder. Got that in today and will bleed the brakes tomorrow. Once I can actually stop again I will be heading to an alignment shop for a final tweak. Then I'm just going to enjoy the car for awhile rather than try to start any more projects.
