Dusting off the 1956 oval rag
oldskoolVWtech
oldskoolVWtech is offline
PostPosted: Mon Apr 14, 2025 10:09 am    Post subject: Dusting off the 1956 oval rag Reply with quote
Time to get our "56 back on the road. This was a full rebuild in 1990 on a "67 pan. It was daily driven 10 years, then sat for 25+. The motor is seized because water got into the top end through the carbs - shortly after I overhauled it. I'll pull it out, tear it down and see what's needed. I'm also going to tackle my first interior job with seat kits. Here we go.
Current VW's
56 Oval Rag: https://photos.app.goo.gl/C1vbVQgzurd3uDBMA
68 Fastback (SOLD):
https://photos.app.goo.gl/auJnGmSnsqMcbzfF8
Dan22
Dan22 is offline
PostPosted: Mon Apr 14, 2025 3:24 pm    Post subject: Re: Dusting off the 1956 oval rag Reply with quote
Bummer that water got in the engine. Is it dual carbs?
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
oldskoolVWtech
PostPosted: Mon Apr 14, 2025 4:37 pm    Post subject: Re: Dusting off the 1956 oval rag Reply with quote
It has type 3 dual carbs. The problem is that water runs off the roof line and drips directly on top of the air cleaners and through their center bolts and eventually into and through the carbs and down the intake manifolds into the cylinders. This usually isn't an issue because I have some coffee can covers that fit over the air cleaners, but I forgot to put them on and then the car sat for many months. The engine turns very hard by hand. I expect to find rusty rings and barrels. Best case, I rebuild the top end and get 'er running again in a week or two.
Current VW's
68 Fastback (SOLD):
oldskoolVWtech
PostPosted: Fri Dec 19, 2025 11:32 am    Post subject: Re: Dusting off the 1956 oval rag Reply with quote
After a couple learning lessons this old boy is back on the road - stronger than ever.
Current VW's
68 Fastback (SOLD):
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Fri Dec 19, 2025 10:43 pm    Post subject: Re: Dusting off the 1956 oval rag Reply with quote
Nice job!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
