Rag-Joint with Extended Beam??
RickRockettph
RickRockettph is offline
PostPosted: Sun Jun 15, 2025 11:32 am    Post subject: Rag-Joint with Extended Beam?? Reply with quote
1966 Type I Volksrod: I have a !0" beam extension & the 'FabShop104' kit for installation... should I cut the steering shaft to leave room for the rag-joint? Seems like I've heard that the rag-joint is not "necessary" with the two U-joints on the shaft but, ... would I like the steering better with or without the rag-joint? Thanks for all opinions!
