Casperfg Samba Member
Posted: Sat Apr 19, 2025 1:44 pm Post subject: Fuel pump |
Greetings from South Texas. I've noticed a slight increase in engine oil level. My 67' 1300 runs prefect. However, an increase in oil level is a warning sign. I'm looking for the highest quality replacement stock fuel stock fuel pump for my 67' 1300? Your suggestions are welcome. I tried a rebuild kit from WW without success.
Thank you! |
Sebastian Gaeta Samba Member
Joined: December 25, 2003 Posts: 341 Location: Ann Arbor, MI
Posted: Sat Apr 19, 2025 4:02 pm Post subject: Re: Fuel pump |
Reach out to Bill Fowler, he knows fuel pumps!
https://www.sparxwerks.com/ _________________ Sebastian Gaeta
'57 Swiss Delivery Oval Agave Green, OKRASA Powered
'63 Beetle Turkis
‘64 Karmann Ghia Coupe Manila Yellow/Black Roof, OKRASA Powered
'64 356C Cabriolet Signalrot
'65 356C Coupe Rubinrot
'66 Single Cab Velvet Green
'67 Ghia convertible Lotus White |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80679 Location: Sneaking up behind you
my3bugs Samba Member
Joined: June 18, 2003 Posts: 971 Location: Moreno Valley
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Sat Apr 19, 2025 5:47 pm Post subject: Re: Fuel pump |
If the fuel pump diaphragm is leaking into the case there should be some evidence of this if you remove the pump and inspect its base and spacer. Fuel leakage would be indicated by the grease washing out, or by fuel staining from the pump body weep/vent hole.
Another common and overlooked source of fuel getting into the oil is a carburetor leaking down the throat after shut down, a sticking choke, or an overly rich setup/adjustment. _________________ 1960 Ragtop w/Semaphores "Inga" |
heimlich  VWNOS.com
Joined: November 20, 2016 Posts: 7587 Location: Houston, Texas
Posted: Sat Apr 19, 2025 6:57 pm Post subject: Re: Fuel pump |
| Casperfg wrote: |
Thank you! |
The WW kits are some of the best. If you rebuilt it correctly you may have needed to prime the pump. I put a NOS pump on one of my vehicles and it took a while to get it to work.
You can also try this guy. He centered his business around 67 Beetles.
https://aircooledartifacts.com/collections/fuel-pumps/products/1300-1600-pierburg-fuel-pump _________________ www.vwnos.com [email protected]
wagen19 Samba Member
Joined: November 16, 2007 Posts: 910 Location: germany
Posted: Sun Apr 20, 2025 12:26 am Post subject: Re: Fuel pump |
| Casperfg wrote: |
Thank you! |
There are more possible reasons for that issue.
Original fuel pumps have a small hole on bottom. If the membrane is leaking, fuel comes out of that hole. Fuel washes the engine case there.
How about fuel consumption, still normal? If not, since when?
Is the carb and the jets original, needle valve, start automatic OK?
Gets the engine warm?
How long are your trips? |
Posted: Sun Apr 27, 2025 10:35 am Post subject: Re: Fuel pump |
Thank you all! Samba is awesome. I got a fuel pump from Bill, very pleased with
the quality and instructions.
