914-6 is offline
PostPosted: Mon Apr 21, 2025 4:47 am    Post subject: 411819771 Reply with quote
I am after a couple of heater sliders the black plastic pins that the cables attach to are knackered---does anyone know where to buy new ones?
thanks
Ian
raygreenwood
raygreenwood is offline
PostPosted: Mon Apr 21, 2025 7:26 am    Post subject: Re: 411819771 Reply with quote
Do you mean the parts attached to the heater levers and cables on the dash blower unit?
If so...just repair what you have. I have broken many of these parts. The plastic is too brittle and when the cables get dry and stiff especially in cold weather...it snaps off the pin.
First fix is lubing the cables. The best lube I have found and it is permanent...is ATF fluid. Never dries up. Very low friction.
In this thread on page 12 I go through the repair. I will also make a seperate thread with excerpts so people can find it.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8250546&highlight=#8250546
Ray
