1969 411 CV's and boots - Which ones will work?
lateral
lateral is offline
PostPosted: Thu May 08, 2025 9:30 pm    Post subject: 1969 411 CV's and boots - Which ones will work? Reply with quote
Hi Guys,
I have a 1969 411 and I would like to replace the damaged boots and maybe also replace the CV's.
I have searched this forum and read a number of posts and also looked through the Classic Volkswagen parts book online.
Am correct that I need the following parts/numbers:?
1. CV's - 211 501 331 (the parts book says 113 501 331 which is a Type 1 CV)
2. Boots - Can I use the the Type 2 CV boot?
Thanks for your help.
Cheers
Greg
wagen19
wagen19 is offline
PostPosted: Fri May 09, 2025 5:00 am    Post subject: Re: 1969 411 CV's and boots - Which ones will work? Reply with quote
lateral wrote:
Hi Guys,
Cheers
Greg
1.) CV´s: the model 1969 type 4 has CV´s in 90 mm outside diameter, so CV´s are 113 501 331, boots are the same as beetle.
The CV´s from model 1970 onwards are 100 mm, type 2. (211 501 331 B) in my list.
There were once different kinds of boots.
2.) Boots: type 4 model 69 with 90 mm CV´s uses beetle boots, from mod 70 on, uses bus boots im 100 mm.
lateral
lateral is offline
PostPosted: Fri May 09, 2025 2:06 pm    Post subject: Re: 1969 411 CV's and boots - Which ones will work? Reply with quote
Thanks again for your quick reply!
Cheers
Greg
