EVC Furnace Access Modification
dsh1705 Premium Member
dsh1705 is offline
PostPosted: Mon Apr 28, 2025 1:25 pm    Post subject: EVC Furnace Access Modification Reply with quote
The shroud that surrounds the EVC furnace also supports the hot air ducts for the furnace. In order to remove this shroud you need to slide the stock rear seat out of the way for access. In my van, with its platform bed, removing the seat base is a non-trivial task. My solution was to cut the shroud at the location where the shroud changes size for the hot air ducts. Now I can remove the shroud without having to move the seat base, and without disturbing the hot air ducts.
David
1705.net
95 EVC
ACU,098
krusovice
krusovice is offline
PostPosted: Mon Apr 28, 2025 2:10 pm    Post subject: Re: EVC Furnace Access Modification Reply with quote
Hi, joining you from the other thread. Smile
do you find it rattles or squeaks where the panels meet?
2001 Eurovan Camper
Sold, but not forgotten:
1984 Vanagon 1.9/4 speed
dsh1705 is offline
PostPosted: Mon Apr 28, 2025 2:12 pm    Post subject: Re: EVC Furnace Access Modification Reply with quote
Nope. But then, the entire van rattles and squeaks! Very Happy
David
1705.net
95 EVC
ACU,098
dsh1705 is offline
PostPosted: Mon Apr 28, 2025 2:43 pm    Post subject: Re: EVC Furnace Access Modification Reply with quote
Let me expand on this a little bit.
I cut this panel with an oscillating multi-tool.
I have found that the panels in the 95 are thicker than the panels I have seen in later vans. I have seen later vans with such thin plastic that the bed near the back of the van is sagging. Panels that are so thin that you are sure they will snap as soon as they are removed. So I am not sure if you did this in a van with thin plastic how it would turn out.
I did not find that I needed to add a gap between the panels, or to add any material to the cut edge - like edging - after creating a gap (both options I thought I might need to explore). It seems to work just as it did before.
My platform bed still uses the shroud for the support in the back - on both the furnace and battery sides.
David
1705.net
95 EVC
ACU,098
OB Bus
OB Bus is offline
PostPosted: Tue Apr 29, 2025 8:19 am    Post subject: Re: EVC Furnace Access Modification Reply with quote
Also joining from the other thread.....
Thanks for the detail. If squeaks or rattles are an issue after this modification, it seems like some grey T-moulding might solve the issue(s).
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
RiversToTheSea
RiversToTheSea is offline
PostPosted: Sat May 03, 2025 4:41 pm    Post subject: Re: EVC Furnace Access Modification Reply with quote
I'm upgrading the 12V electrics and replacing the furnace in my 1995 right now. Thanks for posting this, I think I will do this to mine. I couldn't believe how many screws had to be removed to gain access to the furnace/converter area. Not to mention having to disconnect all the hot-air ducts.
