Spark issue
daveg67
daveg67 is offline
PostPosted: Wed Apr 30, 2025 12:33 pm    Post subject: Spark issue Reply with quote
Hello
Just purchased a 1957 oval that has been locked away since 1990
Nice project
Im stuck on a problem so i thought i would throw it out here
Fitted with a Bosh VJU4BR8 distributor
It had no spark replaced points and condensor and got it running for a few minutes then no spark,replaced points and condensor then after a few minutes the same again.Only use quality parts they were both from different suppliers
Got me stumped
thanks for your help
Dan22
Dan22 is offline
PostPosted: Wed Apr 30, 2025 1:14 pm    Post subject: Re: Spark issue Reply with quote
Rusty or ungreased points cam in the distributor, grinding down the rubbing block?
The lobes need to be very smooth, clean and greased.
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Wed Apr 30, 2025 1:22 pm    Post subject: Re: Spark issue Reply with quote
Why replace those parts again? Was there damage? If so, what did it look like? Maybe the coil is shorting out? Maybe the generator is producing too much voltage?
Lots of items to check.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
daveg67
daveg67 is offline
PostPosted: Wed Apr 30, 2025 1:40 pm    Post subject: Re: Spark issue Reply with quote
lobes are smooth no rust
i was thinking maybe coil
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Wed Apr 30, 2025 1:45 pm    Post subject: Re: Spark issue Reply with quote
Verify that the pass through bolt that connects the points and condenser to the coil is not shorting out on the distributor body. That particular part is very finicky on this particular distributor.
Roads Scholar
Member# 2059
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Wed Apr 30, 2025 2:55 pm    Post subject: Re: Spark issue Reply with quote
Take a multimeter and set it to continuity test. Put one end on the bolt that goes through the housing. Then take the other end and put it on the rotor shaft. When the points close it should beep or pass the test. You can also put it on the bolt and the housing. If it beeps it's grounding out.
daveg67
daveg67 is offline
PostPosted: Sun May 04, 2025 12:03 pm    Post subject: Re: Spark issue Reply with quote
Hello me again with a follow up
Tested the coil with multimeter within specs
Went to a local show and was given a distributor by a good friend
I got home and set up a bench rig i saw on youtube where you spin the drive and it worked Smile
Vw ignition tips & tricks
The EZGZ
iIf your interested
Any way the distributor on the car put up a fight to get out !!!!
I followed the manual set TDC removed the distributor which said at TDC the drive should be perpendicular to the case seam and the smaller segment pointing towards the pulley
Mine is not
i know the engine was rebuilt many years ago did they not put it back in right when they built the engine ??
I put the known working distributor back in but the rotor arm points towards the number 1 cylinder is this correct ??
Thank you
VWNOS.com
PostPosted: Sun May 04, 2025 6:39 pm    Post subject: Re: Spark issue Reply with quote
Don't assume anything based on the distributor orientation. You can find TDC by checking the valves. Once you find TDC, where ever the rotor is that is #1. Connect your #1 wire to the terminal above that and then go through the firing order connecting the other wires.
tasb Premium Member
tasb is offline
PostPosted: Thu May 08, 2025 8:05 am    Post subject: Re: Spark issue Reply with quote
An incorrectly aligned distributor drive is fairly common. Usually only a tooth off.
Roads Scholar
Member# 2059
Kjell Roar
Kjell Roar is offline
PostPosted: Sun May 11, 2025 5:30 am    Post subject: Re: Spark issue Reply with quote
Had a similar problem after changing points once, it was the little bakelite washer where the contact to the points goes through the body of the distributor, that broke, so it earthed in the distributor body.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
