dash knobs & vents, '72 Super, padded dash removed
theyellowbug
theyellowbug is offline
PostPosted: Thu May 01, 2025 11:00 am    Post subject: dash knobs & vents, '72 Super, padded dash removed Reply with quote
For a '72 Super (1302) Wolfsburg production, after removing the padded dash, which years' dash knobs will work? Is this only an electrical issue? I know they must be shorter. I replaced the black plastic steering wheel with the '62-'63 ivory/chrome steering wheel, so I want to replace all the black dash knobs. Will the ivory knobs for '55-'66 fit? And air vents (mine unusable) -- none on offer indicate if they're for padded or metal dash. All the same? All advice appreciated!
Danpa
Danpa is offline
PostPosted: Sun May 04, 2025 1:33 pm    Post subject: Re: dash knobs & vents, '72 Super, padded dash removed Reply with quote
I believe what you need for the defrost vents are available at Heritage VW in the U.K..
https://www.heritagepartscentre.com/uk/113819635-d...ight.html.
https://www.heritagepartscentre.com/uk/111255483-centre-dashboard-vent-trim-for-metal-dash.html.
I used Type 3 knobs (shorter) for the fresh air controls, headlight switch, and wipers when I took off the dash pad of my 70 sedan. I also modified the glove box door and made a new ashtray front to better fit the dash opening. I also sourced a dash handle from a 1200a/Sparkafer from England and a 58 right side grill (no gas gauge, with a trim strip that fits better than a late model).
https://www.thesamba.com/vw/forum/viewtopic.php?t=414792&highlight=steel+dash+glove+box
Dan
67 Beetle (gone)
68 Bay Window Double Cab (gone) sob, sob!
64 Beetle (gone)
77 Scirocco (gone)
73 Squareback (scrapped)
70 Beetle, Finally back on the road after 18 years!
theyellowbug
PostPosted: Fri May 09, 2025 6:19 am    Post subject: Re: dash knobs & vents, '72 Super, padded dash removed Reply with quote
Thanks, Danpa, for all the info. I'll check into Heritage and some other European sources as I'm in Greece. That's a nice looking dash you have there!
