Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 1085 Location: Bath, England
Posted: Fri May 02, 2025 2:22 pm Post subject: When did they stop using Welah Ladies Hat seals? |
Question: When did they stop using Welah Ladies Hat seals? Those behind the clips that hold the trim on Beetle front 1/4s and bonnet (hood). Should they be on a 56? They appear in the VW 56 parts manual as 21.5mm diameter items, but don't specify when fitted. Thanks for any help.
finster Samba Member
Joined: May 26, 2012 Posts: 9781 Location: not far from the madding crowd
Posted: Sat May 03, 2025 1:38 am Post subject: Re: When did they stop using Welah Ladies Hat seals? |
if I remember correctly, my june 56 US spec oval had them. suboval's original 28k mileage 57 oval has them...
and in another thread janerick3 says they were used until 60 then replaced with the push through cups.
interestingly the term witches hat seems to be used but they are more the shape of welsh hats. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
Posted: Sat May 03, 2025 2:30 am Post subject: Re: When did they stop using Welah Ladies Hat seals? |
Thanks for that info. I had suspected that even my 59 had them years ago when I 1st got the car. Somebody was trying to suggest that the later style should be fitted, and then the Welsh hat in addition. Belt & braces. |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 543 Location: germany
Posted: Sat May 03, 2025 3:11 am Post subject: Re: When did they stop using Welah Ladies Hat seals? |
Martin Southwell wrote: |
The new style of from outside fitted rubber seals started VIN 2 539 142, Aug 11th, 1959.
To combine better function and old look, you can put the old style rubber from inside upon the newer rubber seals. |
Posted: Mon May 05, 2025 11:08 am Post subject: Re: When did they stop using Welah Ladies Hat seals? |
Who sells these items? |
stale air Samba Member
Joined: August 23, 2007 Posts: 5579 Location: Senoia Ga, formerly NorCal
Posted: Mon May 05, 2025 2:56 pm Post subject: Re: When did they stop using Welah Ladies Hat seals? |
Many thanks. |
my3bugs Samba Member
Joined: June 18, 2003 Posts: 708 Location: Moreno Valley
Posted: Mon May 05, 2025 3:00 pm Post subject: Re: When did they stop using Welah Ladies Hat seals? |
around here we called en Witches hats for some reason . |
splitjunkie Samba Member
Posted: Tue May 06, 2025 3:32 am Post subject: Re: When did they stop using Welah Ladies Hat seals? |
Wolfsburg West sells them too.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111857219 _________________ Chris
Posted: Tue May 06, 2025 5:01 am Post subject: Re: When did they stop using Welah Ladies Hat seals? |
Nice, I bought some years ago from them, but when I looked yesterday, damn if I could find them. So, thanks for posting.  _________________ WANTED: Henry Veale Santa Rosa plate frames
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2547 Location: Australia
Posted: Tue May 20, 2025 11:09 pm Post subject: Re: When did they stop using Welah Ladies Hat seals? |
my3bugs wrote: |
Same here. Always known them as witches hats for over 40 years _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4739 Location: St Charles, MO
Posted: Wed May 21, 2025 8:57 am Post subject: Re: When did they stop using Welah Ladies Hat seals? |
There are two sizes for those "Witches Hats". A shorter/smaller type was used on the forward side of the Oval dash IIRC...
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
